HD6B solid front idler
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Topic: HD6B solid front idler
    Posted: 15 Aug 2025 at 2:06pm
My latest HD6 purchase (20,xxx serial) is in need of a front idler attachment repair. The tractor has a solid front idler on the left. The right side is in need of replacement idler support fittings which I have, along with the shims. Since I have a solid idler already,  I am hoping I can locate one to match the left. The Berco book we have (1970) shows a part number of AC1247 and/or AC1468. The spoked AC idler appears to be a  622830.
Any help or direction would be very much appreciated. Thank You.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2025 at 1:01pm
I would say be glad if you can find one of any type. Maybe some one like Gemdozer can say if one is more heavy duty than the other. But with the difficulty finding parts for AC machines today, use a lot more care and a bit more time. Like rocking over a berm genteelly, and other such things that are rougher on a machine than you have to be and still move some dirt around.
Oh if more of a show machine, still use which ever you find for now. And keep looking for a matching one.
Edited by Ray54 - 16 Aug 2025 at 1:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2025 at 2:09pm
Correction: Idler is  an AC1486. I have found several spoked units and weld on rings.
Curt Anderson
