AC 715B steering issues
Specialized37 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Specialized37 Quote  Post ReplyReply Direct Link To This Post Topic: AC 715B steering issues
    Posted: 29 Jul 2025 at 7:58pm
Recently bought a 715B (I think) The plate also shows 715D just below the 715B. Steering works great for a while, then starts to feel like it is slipping, then stops steering all together. Can continuously turn steering wheel with no movement at the wheels. Previous owner replaced the orbital valve and thinks that he had the steering cylinder rebuilt. I have been trying to locate the priority valve. I think it may have been removed before the previous owner purchased it. Where should I find the priority valve on the backhoe? Is it possible to properly operate without it since there is a separate steering pump? Thanks
Edited by Specialized37 - 30 Jul 2025 at 6:40am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2025 at 12:44am
Seems my 715 B/D is having steering quirks also - when road driving machine turning when to correct  travel it will make a complete revolution of the wheel in a short time .
 Figure it has to be leakage in the cylinder but on job one can turn wheel and lock wheels in turn position
 The wandering on steering has been there since I bought the machine back in 87 or 88 with 2000 hours on it . I have rebuilt all the hydraulic cylinders except the on on front axle .  I have a Digmore extend a hoe on rear
Post Options Post Options   Thanks (0) Thanks(0)   Quote Specialized37 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2025 at 2:36pm
Coke, thanks for your reply. I have bought a parts manual and have been looking for a service manual with no luck. The service manuals that I do find state that they are for a 715. I'm not sure how accurate it would be. Do you know of any good sources for parts and maybe a service manual? Thanks again
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2025 at 7:38pm
For both posters: When the steering wheels orbitrol provides oil to a simple 2-way hydraulic cylinder, the steering wheel will ALWAYS slowly turn one way or the other. I can tell you on an A-C One-Seventy farm tractor, the steering wheel rotates slowly clockwise. This steer wheel creep is NORMAL, because the displacement of the rod end of the cylinder has less cc's of oil than the other end of the cylinder.  So, back and forth turning of the steer wheel constantly swaps more cc's of oil for less cc's of oil. On the original poster's problem, disconnect both hoses at the steering ram and cap/plug the end of each hose. Now, try and turn the steering wheel with the hoses plugged. I would expect you to NOT be able to turn the steering wheel, or if you can, it would be with great difficulty. If this is true, the steering cylinder must have a terrible internal leak. Over the years, I have fixed DOZENS of hydrostatic power steering tractors for "wandering" while roading. Every time the fix is a seal kit in the steering cylinder or get a new cylinder. Not once in almost 50 years have I ever replaced a steering orbitrol on an A-C machine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Specialized37 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2025 at 11:54pm
Thanks for your response. I will try what you have suggested. Should there be a priority valve somewhere on this setup being as that it has an auxiliary pump on the right side of the engine along with the main pump on the left? Tracing the lines, they do seem to interface here and there between the two pumps. Also the previous owner, after replacing the orbital valve, re-routed a line that was connected from the tank port on the orbital valve to a large line on the right side of the backhoe. He capped off the tee where it was connected and routed the line straight to the tank. If I connect the line to where he said it was originally on the large line, the steering wheel is hard to turn and never any actuation of the steering cylinder. Thanks again
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2025 at 1:20pm
I don't have any idea what the previous owner did. An "auxiliary" pump for the steering?? Well, a machine with hydrostatic power steering has to have a pump to even make it work, so it's not a "option" added to the hydraulic system. For example, I could envision a 12 GPM hydrostatic power steering system pump (at wide open throttle) that sends the first 4 to 5 GPM to the orbitrol and the remaining 7 to 8 GPM to the main pumps circuit to add to its total flow. That could be a possibility.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2025 at 12:17am
One pump - it supplies the steering , loader , backhoe . On mine there was a diverter on one line to hoe to run a hammer also - but I removed that as it was hooked into the extend-a-hoe system . Used the foot valve for extension to run hammer
 When I bought my machine I went back to city that traded it in and got all the spare parts and manuals they had - along with all their service records from day they bought it to they traded it in . I will probably try sealing the cylinder as it seems the internal leakage is worse now over last 3 or 4 years and all the other hydraulic cylinders have been resealed in last couple years except the outriggers- they work fine and no leaks
Edited by Coke-in-MN - 05 Aug 2025 at 12:21am
This page was generated in 0.219 seconds.
