Clutch
Stoges View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stoges Quote  Post ReplyReply Direct Link To This Post Topic: Clutch
    Posted: 24 Jul 2025 at 2:15pm
Pulling in 6000# class with a WD my clutch started to slip, not knowing which one it was. The motor clutch is heavy duty and new last year. The pto clutch snaps in like it should. I don’t know which to adjust, I know I can take shims from the pto clutch but have no idea how to adjust the motor clutch. Any advice would be appreciated. Thanks Bill
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2025 at 3:17pm
no adjustment in motor clutch.  can upgrade to 9 spring pressure plate and use a 4 or 6 button disk for better holding power
Edited by CAL(KS) - 28 Jul 2025 at 3:17pm
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2025 at 6:53pm
6,000 lbs. class is very heavy for a WD. It might be a good thing the clutch slipped before you damaged something in the drivetrain.
Edited by WF owner - 28 Jul 2025 at 6:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2025 at 6:33am
I pulled 7500 lbs with my 100+ HP D-17 and 18.4 x 38 cut tires a few times one summer. Eventually took a tooth off the right bull gear, not damaging the upper pinion gear. Those 7500 lb days then came to an end.
