5015 Allis diesel injector pump question.
Russ P View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ P Quote  Post ReplyReply Direct Link To This Post Topic: 5015 Allis diesel injector pump question.
    Posted: 18 Jun 2025 at 10:39am
My 5010 tractor has a cable operated fuel shutoff. The cable is not stuck but the lever on the injection pump that the cable operates is very hard to move. It is sticky, REAL sticky.
Any help diagnosing and reaping the problem will be appreciated.
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ P Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2025 at 10:45am
That should have said a 5015 tractor and "reaping" should be repairing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ P Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2025 at 3:39pm
I found and corrected the problem. Several applications of PB Blaster on the shaft and some moving it back and forth freed it. Nothing in the area looked rusty but something had it stuck.  Free now.
This page was generated in 0.149 seconds.
