CA First Use - Lost Oil Pump Prime |
dfwallis
Joined: 09 Mar 2023 Location: Texas / Indiana Points: 1050 |
Topic: CA First Use - Lost Oil Pump PrimePosted: 19 May 2025 at 3:11am |
It's held prime for a year then lost it overnight following first use. Found a disturbing flake of probably old gasket material in the line feeding the filter. I assume particles caused the check ball to stick...is that plausible? It primed easily. I guess I'll do an oil change.
1952 CA13092, CA Pickup Plow, CA Cultivator, CA Two Row Planter, Dunham-Lehr GC78 Disc, Grader Blade, 3pt Fm180 Finish Mower
