Allis G fuel problems
Farmer Ruth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farmer Ruth Quote  Post ReplyReply Direct Link To This Post Topic: Allis G fuel problems
    Posted: 02 May 2025 at 9:34am
I need some advice... I have a 1949 G which starts right up but stalls out immediately once the choke is released. It will run as long as the choke is pulled out. I have made sure gas is flowing freely, replaced the sediment bowl with an inline filter, and installed a brand new carburetor. Nothing has changed, help!
oldfords View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldfords Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2025 at 9:45pm
Sounds like it could be sucking air someplace. Check intake gaskets.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2025 at 6:48am
If you can't find a manifold leak, get rid of the inline filter and put a sediment bowl back on as it was designed to have. Most inline filters are not designed for gravity flow.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2025 at 3:46pm
Paul is right.  Lose the inline filter and put the sediment bowl back on.  Sounds like the settings are your carb are a little out of whack too.  Might need to play with the load adjusting screw.
I have read those new Chinese knock off carbs can be pretty touchy to get set up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2025 at 8:49am
Depending on what type of inline filter you have on it is gonna determine fuel flow. If it's a can type fuel filter, they are for fuel pump equipped engines. Install the sediment bulb back on or install an inline gravity fuel filter that goes on an early Garden Tractor. Then see how the engine runs. It may be starving for fuel. With the choke on, it fattens up the mixture..  HTH
Steve@B&B
