7040, 7045 driveline strength
callis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote callis Quote  Post ReplyReply Direct Link To This Post Topic: 7040, 7045 driveline strength
    Posted: 10 Apr 2025 at 10:57pm
What would be the max power either of these tractors could handle in both a farming AND pulling application? I'm refering from the flywheel to the pto and everything in between. What breaks where and at what power? I realize the torque required in farming is a whole different animal than the short stint of pulling but the weak points show in the same places I would assume? Always wanted to slap a 3116 CAT in 7000 series Allis. Have the engine. What hp do I build it to? Can be 150hp-350hp and 400ft/lbs-900ft/lbs torque with factory parts easily. Hence the questions
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2025 at 7:22am
I had two 3116 Caterpillar engines in medium duty trucks, (rollback/winching) service. Both were worked hard, and required cylinder heads from cracking. Both were set close to 250hp. Don't know about the tractor, but I see a lot of the 7000 series with broken transmissions in one form or another at factory settings in farm service.
FWIW of course.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote callis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2025 at 7:41am
Is the transmission problem due to shock loading or are they just not heavily built? I've heard of issues in the 7580 with transmissions I think?
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2025 at 8:08am
You are asking about durability of a 50 year old tractor?  Anything can break anywhere anytime. Having said that - the 7000 was one of  if not the heaviest built per HP tractor. We sold and serviced hundreds and can still count the few failures - most due to lack of maintenance. The first 7030-50's had an issue that showed up on the 4or 5 speed - and the drop boxes could have issues at high hours. That's it. The issue is they are so heavy. You got to have some kind of special class to allow a heavy tractor with an engine transplant.  As to farming with it - the weakest part would be the nut behind the steering wheel :-)  All units went thru beak down testing at 10% over rated power.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2025 at 9:39am
A "3116" Cat engine is 402 cubic inches and a bored block.
Post Options Post Options   Thanks (0) Thanks(0)   Quote callis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2025 at 9:48am
If this wild hair ever does get pulled it will mostly be a farm tractor that is over powered for it's job. The only time full power will get used is probably discing in front of a field fire. It will run down the track once a year at a local farm tractor pull that I'd say has some pretty lenient rules. The reason I ask this in the pulling forum is this is where the most knowledge of stuff breaking probably originates
Post Options Post Options   Thanks (0) Thanks(0)   Quote callis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2025 at 9:52am
If something can be beefed up before being completely together I want to know about it is probably the best way I can describe what I'm asking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2025 at 10:56am
I know where there are a couple that pull 12 MPH "farm stock" classes and are at 500 to 600 HP and have done nothing to the standard transmission for "beefing it up".  You know that all the Farmall's have an additional after-market center bearing on their countershaft in the transmission, right ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote callis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2025 at 12:28pm
Did not know that. But not a farmall fan either.
Post Options Post Options   Thanks (0) Thanks(0)   Quote callis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2025 at 1:20pm
Will a 7040 with only two side gears in the diff be usable or would only a 7045/7060 differential be useable? If a 7040 diff would work I would be happy as I already have 2 7040's with bad engines. One PS and the other PD. Would it be a good idea to add a brass bearing shaft like on a semi axle behind the ring gear to prevent ring gear flex at the pinion? IDK what the technical term is for that...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2025 at 7:15pm
Two-pinion differential is FINE !!! Just carry the oil level higher, like an inch or two above the top sight glass. I have removed the lower sight glass and plugged the hole, then drilled a hole for a new upper one. Been there dun that. Now, if you are talking running road gear, the two pinion should be "needled" on the little gears. Any higher HP puller has that done. Brass rub block behind the ring gear not needed until you have enough cocoanuts under the hood to run road gear or faster.
Edited by DrAllis - 11 Apr 2025 at 7:19pm
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2025 at 9:01am
  Torque limiter will slip at 300 hp +, need six pad plate, double bevel springs pulled tight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote callis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2025 at 7:40am
Thank you very much for all the info fellas! I tend to over build and over think things so your wealth of information is greatly appreciated!
This page was generated in 0.085 seconds.
