d17 175 head studs
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: d17 175 head studs
    Posted: 10 Apr 2025 at 9:28pm
does some one know where i can get head studs for my engine the threads in my block are gettting a little worn i think if i set studs it should be just fine . does some one know the lenghts tall head thanks hud
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2025 at 5:26am
I recently put some helicoils in a WF 201 block for the same reason.
I decided to go to studs instead of bolts. I didn't have any studs for a 3" head and didn't want to take the time to order some, so I took some grade 8 bolts (1/2"-13 for the WF) and cut them to length. I stuck them in the lathe and tapered the cut surface a little to get a 1/2"-20 die started.
I could have cut the threads with the lathe if I was a little more confident in my machinist ability!
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2025 at 9:00am
i usally make every thing but it will be quicker for me to buy some but i have spent enough time looking for them i could have made them
