Bar's Leaks Head gasket sealant
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: Bar's Leaks Head gasket sealant
    Posted: 26 Mar 2025 at 11:49am
Anyone use this stuff? Did it work? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2025 at 12:20pm
I have used the COPPER 1109 stuff with great success.. Not like the slimy goop stuff they sold 30 years ago.  Had a leaking head gasket on an old F150 and i would seal it up and good for about 1 year... Then do it again...
Rebuilt a Allis B and must have torn a cylinder liner o-ring or small crack i missed... Put  6-8 oz in several years ago and never looked back. Ha another B with a small hole in bad spot on lower radiator tank.. fixed that.. Couple other successes.  So far i have never found anything that it would not repair... Some not Permanent, but several months..
the actual "BLOCK" sealer is the silver stuff... Suppose to be as good or better.. Have never had the opportunity to try it... Most of my experience with the 1109 was 5- 15 years ago.
Edited by steve(ill) - 26 Mar 2025 at 12:31pm
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2025 at 1:12pm
Had a ‘99 Ford Taurus, that blew a heater hose while my Son was driving, or course he ignored my telling him to park it, and Mom will pick you up. Continued to drive home till the computer shut down, by then too late. Towed car home, fixed heater hose next day, refilled with coolant, car started right up, but blowing white out the tailpipe, and bubbles in the pressurized coolant reservoir. Tried every block sealer, head gasket repair on the market, got the white smoke out the exhaust stopped, but never could get issue of exhaust going into the cooling system, gave the car away to a mechanic I knew.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2025 at 1:32pm
Thanks Steve and Lars. I'm going to give it a try
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2025 at 2:24pm
Yes. No.
Guessing it all depends on how blown it is.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2025 at 3:06pm
If it does work, it would just be a band aid.  Eventually you are going to have to replace the gasket anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2025 at 3:14pm
The ALLIS B i had a bad cylinder o-ring ( i think) and it sealed it permanently... Head gasket on a  5.4 V8 i did 3 times in 4 years. Truck had 170,000 miles and was not worth the time, effort, or $$$ , pulling engine to rebuild......... had 250 K when i sold it for $2000.
I would agree with Tbone... It all depends on HOW BAD it leaks...  If your burning a quart of antifreeze an hour it will work.. If its pouring out a gallon, your in trouble,
Edited by steve(ill) - 26 Mar 2025 at 3:19pm
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2025 at 3:27pm
I have a WD that froze and cracked the block behind the carburetor (where they all crack). When I bought it, it had been welded but still seeped pretty good when it was warm.
I asked what they recommended, and he said Bar's Leak was the ONLY thing he would recommend. I bought a can, followed the directions and it has been dry for many years since.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2025 at 5:14pm
I think coolant loss has been a problem on his D-15 for a couple of years. I believe a new head gasket was tried. I assume this is the vehicle he is asking about needing coolant loss sealer. Maybe not.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2025 at 5:54pm
The only one that I have seen to work is called "Irontite". I have used it in several different applications.
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2025 at 7:10pm
Worked great on my 2006 Ranger radiator leak.  100% leak free for a few years now.
1952 CA13092, CA Pickup Plow, CA Cultivator, CA Two Row Planter, Dunham-Lehr GC78 Disc, Grader Blade, 3pt Fm180 Finish Mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2025 at 7:04am
My experience was a 2004 Chevy Monte Carlo with the 3.4 V6. Was going down the road and developed a miss and warmed up quickly. So it was blown pretty bad. HOWEVER, at the same time we had a Pontiac Montana with the same engine. Together those two vehicles damn near bankrupted me, no exaggeration, no lie. One thing after another I could not get ahead of it. When that gasket blew I was about broke and saw the Bars Leaks Head Gasket formula so gave it a shot. So racked up even more on the credit card and got the head gasket replaced. 18 months later the engine seized. The van’s frequent trick was to pull the studs that held the rocker arms out of the block. Fix was to drill out and put an oversized helicoil in so you could use a bigger stud. The third time that happened I had them do ALL the rest of them.
GM took the very good 3.8 engine and cheapened it in every possible way to spawn the 3.4. The late 2000’s and early Teens were sure a rough patch in the life of ol’ Tbone! And my GM experiment was OVER!
Edited by Tbone95 - 27 Mar 2025 at 7:04am
Oldwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldwrench Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2025 at 7:51am
Besides its sealing effectiveness, I would wonder (worry?) about its potential for partially plugging the radiator and coolant passages?  I recall as a kid using it at various times on the farm to seal leaks in some old farm truck that would barely run anyway, but I wonder if it would plug up the smaller passages in heater cores and such in modern vehicles?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2025 at 8:36am
the "new stuff" is not the same as the BLACK GUMMY GOO or the SILVER FLAKES that were common 30 - 50 years ago... The "New stuff" does not seem to plug radiator or internal passages.... some how it looks for a Differential pressure, like leaking into the crank case or combustion chamber or external... "normal flow" thru the passages is OK.
Edited by steve(ill) - 27 Mar 2025 at 8:38am
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2025 at 10:11am
Sad but true Dr Allis that this started a couple years ago
Still getting a trace of coolant in the bottom of my D 15 oil pan. I'll crack the drain plug soon and check for coolant. Thanks everyone!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2025 at 10:33am
I’ve been told by a very knowledgeable reliable source that they dump a dose of bars leaks into a brand new car when it’s built.
ekjdm14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2025 at 10:33am
My experience of sealers like this, if you're having trouble with combustion getting in the coolant (pressurising/bubbling out the cap) then there's little point trying them as they never seem to work. If it's just mixing/losing oil or coolant they can be a good fix.
Only exception is blue devil, no personal experience but have heard of it fixing combustion leaks at least temporary.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2025 at 12:59pm
How long does it take for coolant/water to show up in the bottom of the oil pan? Overnight or a couple days? Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2025 at 1:10pm
i would normally add the sealer.. then run the engine for 30 - 60 minutes while i traveled to work / chores / etc.. Let it set an hour or overnight... then do it again.. sometimes it sealed in the first 30 minutes... sometimes it still had a minor leak and took a couple cylces on / off to fix... then monitor daily - weekly until your convinced it worked.
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2025 at 1:23pm
Radiator leak trick my father used back in the late 70s was cracking a chicken egg in the radiator and that plugged a lot of leaks, better than "the store bought stuff". He got ten years out his work pickup and I think the tractor I'm using now got a dose or two.
There is a liquid copper mix I've seen lately.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2025 at 10:32am
No luck. Plan B.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2025 at 10:39am
You're still having coolant getting in the oil ???   Step #1. Leave the antifreezed coolant full in the radiator. NOT straight water. #2. Remove the valve cover. #3. Pressurize the radiator to 12 psi max. #4. Inspect the freeze plugs that are on top of the cylinder head located UNDER the valve cover. #5. If they are dry/no leakage, remove the engine oil pan and inspect for leaking sleeve orings while the radiator is pressurized still. I don't believe you've had the pan off to look at the sleeve orings. You were assuming it was the head gasket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2025 at 11:07am
Thanks Dr Allis. I've pressurized the system twice since the head rebuild. Both times it held 10 psi overnight. Wondering if coolant only shows up in the oil when the engine is hot? Per directions I only used half the bottle of stop leak. I'm trying the rest now. Thanks again
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2025 at 11:25am
Sometimes, yes, maybe only when hot. You had water or coolant ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2025 at 11:28am
Thought it was water but now I believe it's weak coolant
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2025 at 11:49am
Straight antifreeze leaks EASIER than water or a coolant mix because the molecules are smaller. Finding a leak with straight water can be more difficult.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2025 at 12:13pm
Ok thanks!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2025 at 12:42pm
i would run the tractor for an hour and cycle it a couple times before i gave up.... your small leak is one that should easily be fixed by sealer... Its the BIG leaks that are normally a NO GO.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2025 at 1:26pm
Have heard of this but never tried, I think for older kit it'd work OK but newer machines/vehicles have finer tubes in the rad &/or heater core which would likely become blocked by cooked egg.  On the other hand, I've had great luck with ground black pepper. One of our cars has a rotted out radiator which leaked from numerous areas, adding about 8 teaspoons of black pepper has reduced it's thirst from needing topped up every couple hours of driving to checking it in the morning & usually topping off every 3 or 4 days.  Also has greatly slowed down the leaks from my B radiator, this used to just pour out to the point that the fan sprayed it all over the ignition and caused misfires. Now with a hefty dose (1-1 1/2Oz) of pepper it barely weeps, running straight water so it gets drained overnight but an ounce lasts 2 or 3 refills before losing effectiveness.
Lot cheaper than Bars leaks & it smells nice too!
Oh, the copper stuff if I'm thinking right is K-Seal, yes?  This was developed for our notorious Rover K series engines, the damn things liked to eat head gaskets as an appetizer for breakfast (breakfast being your NEW head gasket, head bolts and fresh coolant/oil for added mayonnaise! Then lunch, the bottom end from Glycol poisoning the bearings).  Horrible stuff IMHO, clogs heater cores and rads like nobody's business and ruins your pressure cap and thermostat into the deal. Iit was OK to "buy time" on a dying Rover, to run out the MoT while you saved up for a replacement car, but wouldn't let it near anything I cared about.
Edited by ekjdm14 - 28 Mar 2025 at 1:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2025 at 1:27pm
Yeah Steve, that's my plan. Thanks
