yup windpower is GREAT....
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: yup windpower is GREAT....
    Posted: 10 Jan 2025 at 12:09pm
Edited by jaybmiller - 10 Jan 2025 at 12:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2025 at 12:11pm
those are brand new windmill blades made of aluminum and fibreglas, easily recycled but BETTER to just bury them...out of site, out of mind,.....
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2025 at 12:30pm
Defective? Why are they burying them? This world is soo wasteful. Like you said why wouldn't they recycle them. Cheaper to start with raw product then recycled? Wonder how the geologists will will interpret this for the history books when they dig them up in a 100 years if the world makes it that far.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2025 at 12:54pm
it was probably cheaper to bury them
around here  the lawns of many new homes are covering up 1,000s of brand new bricks as it's cheaper to bury onsite than restack and save.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2025 at 1:36pm
Seems some resourceful uses have been found - grind them up and add to concrete mix as fibers can increase strength . But it seems the life of blades makes the supply beyond what concrete additive market can absorb .
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2025 at 2:02pm
The black eye of “green energy “
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2025 at 2:44pm
Only so much concrete CAN add them to, as well NO Aluminum, the base mounts are pulled, just Fiberglass and plywood/lumber.  Have to run thru a Cement Kiln to add to Cement, too costly and fouls the kilns, Continental Cement inside info on that.  Faster Cheaper and less issue burying ONSITE at the sites, these are also NOT new, are stress fractured older blades, wind erosion on edges leads to moisture intrusion and stress cracking begins, last around 5-9 years then replaced.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2025 at 7:03pm
is it a real picture ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2025 at 7:27pm
Les Kerf View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2025 at 8:16pm
"Green Energy" is a pipedream of the scientifically ignorant and the mathematically inept.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2025 at 10:05pm
yes, sad thing is , if you spend enough time looking at satellites, you can see 100s of these 'temporary storage facilities'. The 'trick' is to revisit them months/years later and hmm,  that's a nice green field.....don't remember that......
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2025 at 4:53am
The problem with those green fields is they cannot load support, they are unstable as those hollow assmblies decay away so slowly. No planting to harvesting no value.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2025 at 6:06am
Then you can put solar panel on those new green fields Dead
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2025 at 6:30am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2025 at 6:33am
MO has several large Wind Farms NE and NC state, along IA border as well these farms owners and additional farms exist in IA, ALL have deposition pits for blades that are failed/failing, one was noted as "Running out of Room" for the blading.
BuckSkin View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2025 at 6:42am
Amen to that... Well said.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2025 at 6:56am
Used new Math and Terdie Emotional Science that isn't!!
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2025 at 8:22am
What are they going to do with the solar panels as they get cloudy and are not working?
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2025 at 9:29am
And the "greenies" say coal fired power generation makes pollution, but at least it's reliable!!  I would say solar and wind make even more environmental pollution and they are not reliable!.
Post Options Post Options   Thanks (1) Thanks(1)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2025 at 9:31am
solar and wind ARE reliable... well, as long as it's sunny and windy...Cry
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2025 at 9:40am
Look at Solar Sites, there will be CONEX Containers along the edges, Solar Arrays have Cadmium, Selenium, ARSENIC, Lead and other nasties in them, a Panel Cracks or is such as Hail Damaged gets placed in a Bag, placed in a Container, HAZMAT and CANNOT be Moved except by HAZMAT Hauler to a Recycling center that Has Yet to be Built and likely Will not.
Edited by DMiller - 11 Jan 2025 at 9:43am
