allis 200 transmissinon gear tooth count
brad7066 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brad7066 Quote  Post ReplyReply Direct Link To This Post Topic: allis 200 transmissinon gear tooth count
    Posted: 07 Dec 2024 at 5:56pm
dose someone happen to know the tooth count on a 200 transmission. all gears including the constant mesh and counter shaft gears
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2024 at 6:58am
If you click on the link below, you can click on a specific gear and it will give you the tooth count.
I'm guessing other vendors have similar information for ordering gears.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2024 at 7:53am
Input shaft 19 teeth........countershaft gear 35 teeth.     3rd gear top 27 teeth.........3rd gear bottom 23 teeth.
Post Options Post Options   Thanks (0) Thanks(0)   Quote brad7066 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2024 at 1:34pm
thank you very much dr allis. by chance would you know what both gears for 2nd are. i need to speed it up. i have d19 bull gears already i will probably have the short pinion  shafts made new this year i had them cut to fit in a 4 pinion diff a few years ago. with my bull gears now i think im around 26 to 1. im thinking about having 3rd 24 to 1 and 2nd at 22 to 1. what is your opinion
