Forum Home Forum Home > Allis Chalmers > Farm Equipment -Knowledge Base
"226" engine differences
Post Options Post Options   Thanks (2) Thanks(2)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Topic: "226" engine differences
    Posted: 19 Nov 2024 at 5:32pm
The famous West Allis built A-C "226" gasoline and LP gas engines have quite a history starting in 1953 with the introduction of the W-226 series used in the WD-45 tractor and also in many other applications. The W-226 was the next generation engine evolving from the W-201 engine first used in the WC/WF and WD tractors and other applications. The W-201 was a square engine with a 4 inch bore and 4 inch stroke for 201 cubic inches. The new W-226 retained the 4 inch bore and was given a 4 1/2" stroke. Compression was also raised to 6.5 to 1. The W-226 was the first A-C engine to be equipped with "Power Crater" pistons, which instead of a typical flat top piston design, the Power Crater was designed like a cereal bowl, which positioned the air/fuel mixture more to the center of the combustion chamber where the spark plug was. The W-226 gas engine was 43 PTO HP at 1400 rated RPM in the WD-45.    In late 1957, the new "G-226" gas/LP gas engine was first released in the D-17 tractor. The new G-226 had the same bore and stroke as the W-226, but the block was different and stronger, main bearings were 3 inches in diameter (instead of 2 1/2 inches), compression was raised to 7.25 to 1 (gas) and rated speed was increased to 1650 RPM's. These changes gave the D-17  53 PTO HP with the tractor being equipped with power steering, which probably took 1 or 2 HP to operate.  While they share many parts, they ARE NOT and never were the "same" engine as some people think. The G-226 continued on in the 170 and 175 tractors until 1974, with flywheel HP reaching the 70+ HP mark from the original 63 flywheel HP of the D-17 engine. Once again, a W-226 and G-226 are different engines.
Edited by DrAllis - 22 Nov 2024 at 10:40am
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2024 at 7:48pm
Thanks for the history lesson Tom! Very interesting. I hope you and your family are well and had a good thanksgiving. God bless you.
Pastor Mike Townsley
Dragfluid View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dragfluid Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2024 at 8:03pm
So Doc, is the bell housing bolt pattern the same throughout? And the crank flange depth? A 175 engine would bolt up fine in a Series 3 D-17?
Thank you!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2024 at 6:28am
The back of the block has the same bolt pattern from a 1934 WC tractor up to a 1974 175 gas tractor. Crankshaft tail protrusion and flywheel bolts all the same too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dragfluid Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2024 at 9:24am
Thank you, Sir. That will make life much easier! :)
Series III D-17
Many others in my life.
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2024 at 2:32pm
That 226 engine found many uses such as a power unit for pumps, generators, saw mills and else that needed a power unit.
