Late curve stick wd
Ol case mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ol case mike Quote  Post ReplyReply Direct Link To This Post Topic: Late curve stick wd
    Posted: 12 Sep 2024 at 8:00am
Is the rear gear ratio same as WD 45 vs curved stick Wd
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2024 at 8:02am
Everything is the same if it has a curved stick. Straight stick trans and ring and pinion are different ratios.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ol case mike Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2024 at 9:54am
I thought it was a WD45 when I bought it curved stick with 45 block but motor has WD internals 1953 I believe is serial number on rear end thanks I was wondering about the rear end if was same as a WD 45 ratio
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2024 at 5:55am
WD Trans., Curved Shifter, and Seat Support changes occurred at WD 127007.
WD 201 Engine with side plate continued to the end of WD production.
G
