WTB: upper conveyer chain #10 rotobaler
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Topic: WTB: upper conveyer chain #10 rotobaler
    Posted: 09 Aug 2024 at 10:13am
Yeah, I know I said I was going to wait until retirement but GOTO is in Canandaigua next year. I need 532235 or 535588. They are the slats to the chain. Also 529252 that is the hay guides that return the hay to the pick up conveyer. thanks
ZachD89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZachD89 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2024 at 10:46am
Try frys equipment in Williamsport pa
Edited by ZachD89 - 09 Aug 2024 at 10:48am
37 A,37 Waukesha B,35 WC,38 WF,M crawler,49 WF,49 WD,53 WD45,39 and 40 RC,47 WC,41 B,39 B,48G,48,C,59D10,D21,IB,B10,B12,B208,B1,Roto Bale Loader, sp100 combine, allcrop 66, L3 Gleaner
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2024 at 8:25pm
You ever been there? You need a trail of breadcrumbs to find your way out. Great people and they know where everything is. Already tried there
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2024 at 6:37am
Matt Scott had those hay guides at one time.
http://lonsallischalmers.com
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2024 at 1:00am
I have a couple of the #10 feeder takeoff's from a converted back to the standard.. I  will check if they still have the chains and tines...Dale
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2024 at 6:46am
Thanks. I am missing most of the tines. Maybe i found a nos one in kansas ( schmidt and son). Figure i am going to have to find a manufacturer to make a run of them
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2024 at 12:10pm
Is your chain 45 or 55?   I know I have used fingers... Poss a new set also... looking for the bars...  Upper conveyor sheets metal assy... I know I have feeder chain assemblies and maybe a complete upper chain assy...  You see I wanted #10  and there were none..so starter to do it the hard way...Then one day I was driving cross country in KS and in the middle of nowhere... End of story...Dale
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2024 at 2:53pm
Mine is missing the entire chain assembly for the upper conveyor. And the four "fingers" the direct the regurgitation back onto the lower assembly
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2026 at 6:28pm
Bump
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2026 at 7:04pm
So, it looks like i need a plan b. I have a bunch of extra slats for the pick up and they look like a good starting point . Can someone who has number ten loan me one slat and i will use it as a template. I give give you what ever you want for a security deposit. Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2026 at 2:59pm
.......I knew I took pics when this post started.  I found them and tried to revisit the scene but a lot of snow....Want to give me a call?  I think I can help out. Just give me a heads up.   Dale     715-781-2055
