Injection pump help
New Allis Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote New Allis Guy Quote  Post ReplyReply Direct Link To This Post Topic: Injection pump help
    Posted: 13 May 2024 at 7:14pm
I have a 1974 7030 with a Roosa Master DM pump. It's gradually begun to start hard, followed by lack of throttle response and low power. I'm quite confident it's the pump and not engine mechanical. I can not pump fuel through the pump with the plunger. It initially would pump slowly through (with the return hose removed) and now won't pump anything through even with the check valve removed. The plunger completely stops in mid-stroke. It pumps fuel as it should with the line disconnected at the injection pump. I've removed the top cover to inspect for anything that doesn't look right and removed the inlet cone to inspect the screen for debris. All appears ok to me. Is there any other checks to make before sending the pump off to the rebuild shop? Thanks
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2024 at 7:24pm
Probably just due for a proper rebuild.
rickymotorbrains View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rickymotorbrains Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2024 at 8:21pm
Did you check the filter where line goes on the pump
Post Options Post Options   Thanks (0) Thanks(0)   Quote New Allis Guy Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2024 at 10:57pm
Yes i did. It was totally clear of any debris
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2024 at 4:51am
Injection pumps wear and get "tired" just as we do. Certainly wouldn't hurt to send it over to Ed for evaluation to start, and go from there. I always send the nozzles, (injectors) into the fuel shop at the same time to be balanced/calibrated to the pump myself.
That's All Folks!
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2024 at 8:07am
You ask for checks - we always remove the fuel inlet hose and use a separate fuel supply to the pump. Like a 2.5 gall jug of clean fuel with a hose connected to the pump inlet. Down through the years we have have several calls per year "we sent the pump off and it is still doing the same thing". A new pump with a leaky, as in air, or restricted fuel supply (or restricted return to tank) will not fix these issues. That is the check we use to determine the need for rebuild.
Post Options Post Options   Thanks (0) Thanks(0)   Quote New Allis Guy Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2024 at 12:29am
Thanks everybody for the input. I was going to have my pump rebuilt but the local diesel place had one ready to go on
the shelf. I installed it and it starts and run like new. Thanks again
