D-19D won't start |
rrhead(SD)
Joined: 11 Sep 2009 Location: Canton, SD Points: 441 |
Topic: D-19D won't startPosted: 12 May 2024 at 7:31am |
First time my D-19D has not started for me in the Spring. Fuel is on and in filters. Someone said the plunger is stuck in fuel pump. Any suggestions on fixing this would be appreciated. rrhead(SD)
2 WDs,WD45,D-14,D-17,D-19D,180,7020,6080FWA,6080 2wd, 6080 2wd(cab),8050FWA,8550,4W-305,Massey 8250. Gleaner L3, R62 &R65 Agco-Allis 1616H & 1920H, AC 720, Terra-Tiger
EPALLIS
Joined: 12 Sep 2009 Location: Illinois Points: 1180 |
Posted: 12 May 2024 at 9:28am |
Hi: Curious as to why the choke lever is pulled all the way back towards the driver? On mine it is always pushed all the way forward. I choke mine a little bit (perhaps half way), then push them forward. They don't ever sit all the way back in the that position.
rrhead(SD)
Posted: 12 May 2024 at 9:32am |
It's the on off lever to the pump. That is the on position. rrhead(SD)
Richardmo
Joined: 12 Sep 2009 Location: Rolla mo. Points: 1752 |
Posted: 12 May 2024 at 10:51am |
Take the top cover off of the pump.
check to make sure the shut off lever is moving. That will stick and cause it not to start. Just had to do this to a D 15 diesel that had been setting for awhile. |
rrhead(SD)
Posted: 12 May 2024 at 11:42am |
Thank you very much! I will give it a try. rrhead(SD)
