D17 series iv head cylinder
waw1962 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote waw1962 Quote  Post ReplyReply Direct Link To This Post Topic: D17 series iv head cylinder
    Posted: 11 May 2024 at 11:18am
uploads/24759/d17_core_plug_2024-05-12_10-43-27.pdf
I've read alot about frost plugs, but when I look at the head from my D17 series 4, there are only two, and they are more like core plugs... not the button type pop in plugs shown and discussed.  I can't find new ones online, as I'm in the process of putting a new head gasket it, thought I'd change those too.  Any help on these plugs and why are they different than what I find online?  Thanks.
Edit... the plugs I took out are about 1-1/2" by 1" and solid.
Edited by waw1962 - 12 May 2024 at 10:44am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2024 at 4:25pm
AGCO dealership.
Post Options Post Options   Thanks (0) Thanks(0)   Quote waw1962 Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2024 at 4:54pm
I looked at an AGCO page, pulled up the D17 head parts list.  The "core plug" shown is not what I have.  I flipped the head over, and drove the two plugs out of the top.  They are solid pieces, 1-1/2" long, 1" diameter.  Could someone have rebuilt it before, and substituted a solid plug instead of the "cap" type shown?  I tried to include a picture, but can't get it down to the 2mb size limit.  Thank you, Dr Allis.
Post Options Post Options   Thanks (0) Thanks(0)   Quote waw1962 Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2024 at 4:59pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2024 at 6:04pm
Didn't come from West Allis with anything like that in it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote waw1962 Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2024 at 8:05pm
I'm wondering if I can replace with standard freeze plugs?  Not sure why these were in the head.  Correct me if I'm wrong, but there should only be two in a 1968 D17 Series IV, yes?  Thanks again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2024 at 6:53am
Are you looking for #5
Post Options Post Options   Thanks (0) Thanks(0)   Quote waw1962 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2024 at 7:02am
Yes, but curious about the plugs I pulled out.
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2024 at 6:19pm
Those are not replaceable core plugs. They are permanent plugs not mean to be removed. All D17 cylinder I have seen, have that style. They can be identified by a tapered bottom towards the center and are solid steel. Not flat bottom like replaceble core plugs.
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote waw1962 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2024 at 6:56pm
Well crap.... now what?  Clean them and the bore up and put them back?   Haven't done this before, in case you hadn't guessed.  And I'm guessing, being permanent, very slim chance of ever leaking?   I am taking it to a machine shop this week, maybe they can save me.  Thank you.
Edited by waw1962 - 14 May 2024 at 6:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2024 at 7:07pm
When looked up 230357 it shows the plug.
Alex is it pressed in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote waw1962 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2024 at 8:02pm
looks pretty close to the plug in my post... I haven't found any new ones online.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2024 at 8:27pm
Do you need the two.
Post Options Post Options   Thanks (0) Thanks(0)   Quote waw1962 Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2024 at 4:42am
I do need both. No sense in having the head reworked and then not install new plugs. Thanks.
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2024 at 7:41am
[QUOTE=Mikez]
[/QUOTE
That looks suspiciously like a Power Cell
This page was generated in 0.127 seconds.
