Small Inverter Welder
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Topic: Small Inverter Welder
    Posted: 20 Apr 2024 at 8:15pm
My GO TO welding is a 225 amp Miller DC Thunderbolt.. about 25 years old..
Been looking at a couple of the new "INVERTER WELDERS"... See a 200 amp unit at AMAZON for $150.  Great reviews... About 15" x 12" x 7" ... weight 11 pounds !  They say they will weld with 5/32 rod.. I only use 3/32 and that would be almost 100% duty cycle !
Personally never used one, but thinking about getting one to TEST.. Cant beat the price and the portability would be nice !
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2024 at 10:30pm
 Well, Steve,,,I gave one of those at Harbor Freight a darn close look when my Lincoln 175 was threatening to bail out on me earlier,,,,,
 I really like the small size for portability, but was concerned that the guy at HF said these machines use very short leads because of the smnall welder size,,,,,??
 Anyway,,,I'm sure glad that you have offered to do the trial run on one of these for us,,,,ClapClap
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2024 at 7:57am
YEA... i look at that.. The stinger and ground are 10ft long.. The power cable is normally 6 ft and 12 gauge ..... Just like the plasma cutter , which i put a 20ft 10 gague power cable and 20 ft ground cable.. ... 10ft for the ground and stinger might be OK...but i would change the 6 ft power cable to  12- 16 ft. and probably 10 gague... Most are a 110- 220 power inlet that senses the voltage and switches itself inside.. Normally i would use the 220v... Keeps the amps down and the duty cycle up.
I plan to get one... maybe not for a few weeks... not sure.
Edited by steve(ill) - 21 Apr 2024 at 8:04am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2024 at 8:40am
Power in = power out , inverter just increases frequency , then transforms and rectifies the output to change polarity .
 I have both a Miller 304 and Pow-Con 180 inverter welders , but both can SMAW, MIG, TIG weld and with Miller have water cooled TIG torch and high frequency start , Pow-Con is scratch start so hard on tungsten's .
 Pow-Con weighs around 50 pounds and wire feed unit about 15 - without wire roll of .035 / 70S wire . Use it for field welding as can power with 12 HP generator and either stick or wire weld , away from shop.
 Use 1/8 th rod for everything except SS where will use smaller rod for cast iron repair .
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2024 at 9:22am
what the inverter does is get rid of that 50#- 100# Transformer inside the welder... And makes it 1/3 as big.... I dont think one of these small ones is a daily user.. But i hate taking the 150# Miller Transformer welder to the farm for a 30 minute job, then packing back up to bring home... Dont need the TIG or wire feed... just a decent STICK for 3/32 rod.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2024 at 12:49pm
Well, i ended up ordering one of these welders on Amazon.. Looked at the reviews of several brands. The review on THIS BRAND mentioned that the power cable was 7.5 ft long, stinger and ground clamps were 500 amp models and the cables were 10 ft, 2 gauge instead of 4 ga.  All the brands look about the same and have basically the same power rating if your looking at the 200 amp models. They are 110 - 220 volts input.. There are smaller 130 amp models that run on 110 v only. Didnt want that.. This one also had $30. off last week so i got it for  $120. including tax.
Edited by steve(ill) - 03 May 2024 at 3:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2024 at 12:51pm
You can see the physical size of the stinger and ground clamp compared to a 10 inch vice grip.. Also gives you and idea of the welder size. And the weight is about 10- 12 pounds.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2024 at 12:56pm
No time to read the directions ( Wink.. ) ... Just plugged it into a 220 v 50 amp welding receptical and go... I thought there were going to be several "buttons" on the front to select rod size, hot start, etc... no... there is a resistor knob that goes from 20 - 200 amps and you see that on the digital read out. I normally weld at 90 amps on my MILLER.. Set this at 90 amps and it "says" your good for 3/32 rod ( 2.5 mm) .... Go to 92 amps and the readout says 3.2 mm rod..... guess that just gives you an idea of the amps needed if you know the rod size..
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2024 at 1:00pm
Just played with it 15 minutes before lunch.. Rand a 309 stainless rod, 6010 rod and 7018 rod... all i use is 3/32 rods and normally around 90 amps.... This gives you an idea of the quality of the weld.. ..  weld on the right is using my Miller 225a DC Thunderbolt ( 25 years old) as a reference of my ability. I tend to WEAVE a little side to side , so these  beads are like 5/16 inch wide.
Edited by steve(ill) - 03 May 2024 at 1:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2024 at 1:07pm
I then got the "adaptor plug" that goes from 220v to 110 and plugged it in. You dont have to select anything.. The welder changes Internally to the correct input voltage... Tried to weld 6010 and somewhat disapointed at 90 amps.. Tried 95 and 100 amps. You could weld about 1/2 inch and then it would "stick" or "pop" and you had to start again.. I was hoping it would work better than that... Guess i will  READ THE BOOK and trie it a few more times. I planned to use the 220 90% of the time.. but would be handy to have the 110 available in some areas... Maybe using a 1/16 inch rod would work better as you could set the power down to  50- 60 amps... but i always use 3 /32 rod.
This is also a STRATCH TIG welder, but it does not come with that torch head. you have to buy that extra.. I didnt plan on ever using that options.. Just wanted a very BASIC portable stick welder.
SUMMARY .... does seem to do the job.. Seems like you have to "pay more attention" to what your doing... but maybe thats just me and only 15 minutes of testing ??
Edited by steve(ill) - 03 May 2024 at 1:12pm
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2024 at 9:53pm
i think i will stay with the lincolns and millers
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2024 at 9:39pm
Played with the welder for 30 minutes yesterday. Getting better at understanding the difference between an inverter and transformer welder..
230v works great on 3/32"  7018 , 6010 and 309 stainless... I also have some Super 600 and MG500 that i "inherited" from a past life. That rod is .075 inch diameter or half way between 1/16 and 3/32 ..... I think you can weld it at 60 amps instead of 90 like i use on the 3/32 ..
The problem is when your plugged into 115v , the welder wants to pull 30 amps INPUT  to get 90 amps output.. Most house circuits are 20 amps so your only going to get about 60 - 70 amps OUTPUT... Thats why the 3/32 rod spits, sputters, and sticks.. You set it to 90 amps output, but i think your only getting 60.... I tried the Super 600 and MG500 and they weld GREAT.. so i think that proves the point.. I do have a 30 amp 115 v supply in the work shop, i may try that with the 3/32 rod to see how it goes.. Also have 5-10 pounds of the MG500- 600 rods so that should last forever if i need to weld on 115 v 20 amps INPUT in the future.
------- if i am readying the SPEC sheet right... you need 31 amps INPUT on a 115v line to get 93 amps OUPUT at the stinger..
Edited by steve(ill) - 04 May 2024 at 9:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2024 at 10:54pm
that super 600 is sweet with about any thing but its real pricey now  its kind of a mirical rod
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2024 at 7:25am
I read it as ...you need 42 amps to strike the arc, then  31 amps to lay the bead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2024 at 8:37am
I think it says at
60% duty cylce, you get 120 amps OUTPUT to the stinger using 42 amps INPUT.
100% duty cycle you get 93  amps OUTPUT to the stinger using  31 amps INPUT
and that is on the 115 volt input... ( who has 30- 40 amp 115 volt service in the shop ??)
so using the abve numbers, at 20 amps INPUT you could get 60 amps output, which is plenty for the 1/16 inch rod or the .075 inch MG rod.... but NOT 3/32.
and HUD is right.. THe MG 500 and 600 rod is GREAT to run.. but cost 10X as much as the "off brands"... OR MORE !
Edited by steve(ill) - 05 May 2024 at 8:42am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2024 at 2:58pm
Unlike traditional pure  'transformer' based welders , inverters aren't necessarily 'linear'.
It'd be nice to see a real datasheet and schematic.
BTW I have 120 V / 30 A in my shop. A leftover from some electronics I was working on 30 year ago.....
RP Farms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RP Farms Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2024 at 7:41am
I have had an Everlast powerarc 200 inverer stick welder for about 10 years and absolutely love it.  It is light, easy to move around, I can run it off of a generator (make sure the generator is less than 5% THD aka clean power) for field repair or fab work.
I built a 60X120 horse arena with an attached 60' round pen using oil field pipe and uscker rod and burned 5/32 6010 rod with no issues whatsoever.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2024 at 7:43am
  Hey Steve,,I'm still looking into the "pistol" looking hand held arc/tig tool as well as those machines that Harbor Freight carries similar to the machine you settled on. I want the portability of  120,SO, what size Power wire would work for a 50 foot extension cord??
 Also, I do not find the MG500 or the Super 600 rod on Amazon or Ebay,,,??
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2024 at 7:54am
according to this website....
... 12AWG
BUT, and this is a big but.....
That drawing shows I1max to be 42 amps ! That should blow the 20A breaker the unit's plugged into.
What is 'weird' is that at 230 input, I1max is 39 amps ! ???
Normally when you double the volts, amps gets halved.....
It's be nice to hear from someone that HAS one of these guns.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2024 at 8:47am
If your using a 3/32 rod you will need about 90 amps OUTPUT  on the welder.... On a 120 v system that would pull about 40 amps INPUT... on a 240v system that would be about 20 amps INPUT.... The 240 v setting on the chart is for 200 amps OUTPUT.. your not welding with a 3/32 rod at 200 amps..
This is why i say this are a little FUZZY on the "explainations".... YEA, you need 40 amps ( or 35) at 120v to get the correct output for 3/32 rod... Problem is like JAY says, your only going to get 20 amps INPUT at most houses.. so your OUPUT is going to be in the 40-50 amp range.. You can barely weld with 3/32 rod at that setting.. You can throw out goobers and gum balls, but hard to do a GOOD JOB..
I was able to weld with 6010 3/32 rod and do a half assed job on 120v... the 7018 rod would weld 1/2 inch bead then STICK.. over and over and over... you COULD do a small weld, but it was not easy....
The SUPER rod i used i had got from a past employer when they closed.. Probably only available at a WELD SHOP ... NOT Wal Mart...and it cost 5X what 7018 rod cost... You can buy a 1/16" rod at the Hardware  Store or Amazon, etc.... That size rod will weld at 30- 40 amps so it will work on a 120v system... Problem is that small rod welds REAL FAST and only lasts a minute and its GONE.. But for a small job it could work.
Edited by steve(ill) - 22 Sep 2024 at 8:58am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2024 at 8:53am
If i was going to try  a 120v welder, i would expect it to try to pull close to 20 amps. Using a 12 gauge extension cord ( or a section of 12-2 ROMEX) would be the best bet.. With a 14 gauge wire you can only pull 15 amps and that might not do so good.
Here is the VERY SMALL ROD that would probably be best to use with a 120 v welder.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2024 at 9:12am
Like JAY, i would like to see someone buy one of those hand held and weld with 3/32 rod and see what they think. I have seen a couple You Tube videos and some seem to have some success and others are welding GOOBERS.. The math just dont add up for a  120v welding 1/8 rod ....... and is VERY shetchy using 3/32...
Also i have enough trouble getting a stinger into some of the OUT OF POSITIONS i weld.. I can imagine holding a gun the size of a 1/2 inch drill and trying to get into position... but again, this is a more of a TACK welder or 1/2 inch bursts in open areas.
Edited by steve(ill) - 22 Sep 2024 at 9:13am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2024 at 9:13am
There is a problem in trying to 'do the math' as these are inverter tech welders and not just a transformer.
With the 'old skool' AC transformer there is a simple power in-power out math, however inverters change input power 120v/20a/60hz to  high frequency DC and store in capacitors, so you CAN get high amps out ,for a short while (aka 'duty cycle' ).
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2024 at 9:19am
i would agree to some extent Jay.... but a 3pound welder dont have much room for a big capacitor... and the SPEC sheet clearly said it puts out 120amps a 42 input amps and puts out 90 amps at 31 input amps....( at 120v input)....... thats about 3 to 1 ..... so i say at 20 amps INPUT ( normal house), you MIGHT get 60 amps output..... VERY MINIMAL for 3/32 rod..
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2024 at 9:28am
this chart shows how you MIGHT be able to weld 6010- 6011 3/32 rod with a small welder... the 7018 would be very questionable..
The 1/16 inch rod is easy to get in the right amps.... remember, what ever the OUTPUT amps is listed, you need about 1/3 of that as the INPUT AC POWER.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2024 at 4:25pm
when I used mine on 120 volt. I used 1/16 rod. I can weld down to 20 amps on thin metal with it and it hold an arc very well. Al so never use 120 as 240 works much better. It will plasma cut  and tig weld on 120 OK. Long as it’s thin. The high frequency hot start has made my thin metal welding look much better then before it’s just so much easier. I’m going to order a new MiG welder soon. My old Lincoln works good I just want a newer one. The multi process inverter I have is a Lotus it had very good reviews on Amazon and a few YouTube welders all rated it favorably. Chuck did a 1 year review of it and was still satisfied. I’ve had it for 2 years and really like the way it welds. Came with stick. Tig foot pedal was optional, and plasma cutter. The ground cable is a little short so is the stick working clamp.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2024 at 8:47am
Hey Dakota,,So, you have one of those machines like Steve does,,?? I like the review and think it is what I am looking for ,,,just small stuff in the shop,that you can pick up when a quick job comes up,!! I dislike having welding leads all over the floor and usually keep them rolled up as tripping hazzards. Something like this "portable" looks interesting. I also want to try the Tig.  I'll look see if Anazon has one  since you and Steve have been having great results with yours,,,,. Did yours come with an adapter from 120 to 220?
Edited by desertjoe - 27 Sep 2024 at 8:49am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2024 at 9:31am
you gots to read the fine print.. Some are 240v plugs with an adaptor down to 120v and some are 120v plugs with an adaptor UP to 240 v.. Mine came with a 240v 50 amp welding plug setup to work. I bought this specific model because the REVIEWS said it had an extra heavy stinger, ground clamp and #2 cables on it..
Mine did not come with a TIG torch.. that is EXTRA.. again, YOU GOTS TO READ THE FINE PRINT if you want more bells and whistles.
Edited by steve(ill) - 27 Sep 2024 at 9:42am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2024 at 7:45am
mine came with a 220 plug and a adapter to plug into 110. I have it on the same cart as my mig and share a tank. The air pressure regulator for the plasma is built in. It also came with the Tig torch has hight frequency start and pilot start on the plasma. It’s about the size of my mig 140 and about half the wieght.
This page was generated in 0.273 seconds.
