1920H ignition coil?
rrhead(SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Topic: 1920H ignition coil?
    Posted: 09 Apr 2024 at 4:06pm
I am trying to replace the ignition coil on my 1920H. Can't seem to get the cover off the back of the engine. What do I need to do get to the coil? Any help would be appreciated. Thanks. rrhead(SD)
2 WDs,WD45,D-14,D-17,D-19D,180,7020,6080FWA,6080 2wd, 6080 2wd(cab),8050FWA,8550,4W-305,Massey 8250. Gleaner L3, R62 &R65 Agco-Allis 1616H & 1920H, AC 720, Terra-Tiger
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2024 at 6:17pm
Remove the engine. Do not let the drive shaft come off the hydro or you will have a vibration!  Take the 4 bolts out of the hub on the engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2024 at 9:08pm
Thank you for the advice. Will give it a try. rrhead(SD)
