pulling tirre pressure
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Topic: pulling tirre pressure
    Posted: 28 Mar 2024 at 10:46pm
i pul  my  farm stock CA in second gear , 13-6 fFrestones.  What tire pressure is best under all track conditions.
dgerth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dgerth Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2024 at 4:23am
Geeze Ken, a loaded ? if ever man!!!
FYI, I start at 6 and go up or down as needed. Not one pressure is good for all. These are just MY opines that work for me.
Good luck my friend,
dan
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2024 at 6:48am
Rim width, tractor weight, lug height, lug sharpness, tire speed, etc, etc, etc ALL EFFECT what is the best tire pressure for your tractor. Let us know where you wind up !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2024 at 7:42am
There is no "one size fits all". Every track is different. Weight changes will affect the optimum tire pressure. You have to look at your tire track after pulling away from the sled, dipped in = too much, humped up = too little. Experience is your best guideline.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2024 at 7:58am
For us big heavy tractors, like 11,000, 12,000 etc, we kinda use the generic rule of 1.5 psi per 1000 lbs wt. So my 11,000 tractor generally runs 16.5, adjust from there, this is radials, but may be a starting point for anyone. So a light 5000# would run 7.5psi. etc.
