wd and d17 iv pistons
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: wd and d17 iv pistons
    Posted: 15 Feb 2024 at 6:58pm
i have scored a d17 series 4 engine for my wc puller project has any one measured the pin hieght on the wd piston and the d17 piston ? can the wd pistons be milled down to make 12:1  wondrering about useing reliance wd cylinder kit 470283616  if i read it correctly that part number is a flat top 4 1/8 piston
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2024 at 9:25am
any one know what or whos brand , pistons i need for 4 1/8 bore  d17 rods , crank to make 12:1 compression
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2024 at 8:07am
Hud, I've got a set of 4&1/8" WD flat-tops that might work for you. We've discussed this in the past but not sure what compression ratio people thought they would make with a 45 crank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2024 at 9:55am
any chance you can measure the center of the pin to the top
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2024 at 6:30pm
2.550" flat tops 4 1/8" makes 11.3 to 1 as I've outlined in the above "D-17 piston" post. So, more than that like 2.600" flat top 4 1/8" would be close or more than 12.0 to 1.
Edited by DrAllis - 17 Feb 2024 at 6:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2024 at 6:33pm
BTT
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2024 at 10:21pm
over looked that post ,     but i did measure  the part number 229717 4 inch pistons that i removed out of it ,   couldnt find that part number in the agco parts book listed for series iv  . i got 2.835 pin hieght and .352 from the top of the deck to the  top of piston  not bowl at tdc , did not measure the volume of the bowl .   reliance dosnt say what compression ratio their 4 1/8 wd flat top is      so their sould be plenty of room for the valves to open and close    it would be nice to have a dished or a bowl piston  with that flat head  hope i aint missing somthing
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2024 at 12:51am
Knowledge Base info: "Compression calculators for 226 engines" near bottom of the page. My own personal notes have a 170 (8.0 to 1) power crater piston at a .263" to .265" deck clearance at TDC. The 175 (8.25 to 1 ) power crater piston has a deck clearance of .230" to .235". This is measured to the highest part of the piston at the piston pin centerline. A D-17 piston ( 7.25 to 1) should measure about .368" to .370" deck distance. So, WD 4 1/8" flat tops need to measure a deck distance of .263" to .265" or less to be more than 11.3 to 1. Probably more like .230" to .235" for 12 to 1.
Edited by DrAllis - 18 Feb 2024 at 11:39am
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2024 at 6:02am
My flat-tops measure 2.375 c/l of pin to top.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2024 at 11:41am
BTT
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2024 at 11:41am
food for thought ,I don't like a flat top piston for a 226 they don't have the bark , I have gone back to cupped pistons for a burn chamber(power crater)
Sealed power number 1728 is a 201 cupped 4 1/8 piston, fit right in ,hard to find,
m&w ap46 also fits may have to cut top off ,I think I have some used left
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2024 at 11:49am
SP-46's I used to remove .170" off the tops and had 240+ psi cranking compression, Always called it 11 to 1 or a little better. I like the bowls too.
Edited by DrAllis - 18 Feb 2024 at 11:49am
