You know it’s a bad day on the farm when
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Topic: You know it’s a bad day on the farm when
    Posted: 29 Jan 2024 at 1:51am
When it’s around midnight and you go downstairs only to find out that the shower drain is plugged up tight. You’ve got to get that unclogged without waking up your girls. It’s got to be made to work because the softener is about ready to run and my daughter takes her shower in the morning before she goes to her teaching job.
@ 1:50, Got her done. now to clean up the mess.
What’s your bad day?
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2024 at 5:47am
When the temp gets above freezing and I find water running out of my well house because the heat lamp blew. County water gets expensive when 230,000 chickens are thirsty
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2024 at 7:25am
List is too long for this thread 😂
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2024 at 7:26am
WOW. I guess it must be fixed now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2024 at 7:45am
so now the girls have a schedule that each of them ,once a month, cleans out THEIR shower drain ???Big smile
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2024 at 8:10am
Dump a cup of sulfuric acid down the drain about every other month and let it set about 15 minutes before rinsing clear. Pour it in slowly and if a clog, do not allow it to dwell onto any surfaces if possible to avoid any staining.
Sulfuric acid is one of the main components in drain cleaner. Straight from a container it is much stronger than concoctions marketed for the purpose like "Drano" as instance. Hair, grease, and soap melt away easily but don't splash it, nor get onto your skin. Won't hurt you but can burn.
No drama, just reality.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2024 at 9:06am
I tried that here. All 3 got sick before the drains were clean so I just do it
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2024 at 9:12am
they need to do it more often then !Cry
either that go  muck out the cow barn or clean the septic tank..LOL
There's a silly long plastic  barbed 'tyrap' I bought from China... does aGREAT job of snagging hair in sink drains. Buy 3 different colored ones and pose a competition, winner gets  of the list. now remaining 2 have to battle...
