Allis Chalmers 714 headlight bulbs
Jesse175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jesse175 Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers 714 headlight bulbs
    Posted: 09 Nov 2023 at 1:37pm
I have a model 714 and it has 4 small round headlights.  2 on each side of the hood.  I cannot locate replacement bulbs.   I believe the number on the bulb is T36962.
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2023 at 7:10pm
I have gone to lawn tractor salvage yard and found a couple sets of those bulbs. Good luck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2023 at 7:00pm
Not that this will help you but part numbers. AC #2087709. Simp #172048.
I want to say there has been this question on here and someone found another bulb to put in there.
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2023 at 9:30am
You might look up similar LED replacement bulbs. Search on the same socket style and voltage.
Chasing function over authenticity, I have installed fully housed LED lights on some of my tractors. Super bright for plowing snow at night.
One set was $16/pair, bolted on, wired up, working.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2023 at 11:43am
I have a 712S with similar lights.
I removed all 4 bulbs to get their ID number.
Only one bulb is readable.
It appears to be T3 ECEE
G
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2023 at 8:05am
Amazon has them: Satco S1972 50 Watt $12.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2023 at 6:38am
This is T3606E
Edited by Mikez - 16 Nov 2023 at 6:41am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2023 at 10:42am
https://www.amazon.com/HQRP-Headlight-13AD678G034-13AN688G034-13AC762F000/dp/B07SSJG5B9
HQRP 2-Pack Headlight LED Bulb compatible with 925-0963 725-0963 1772001 725-0963P 725-0963 Ryobi 13AD678G034 13AN688G034, Yard Machines 13AC762F000 (2008) Lawn Tractor Headlamp
