CA Hand Clutch Adjustment?
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Topic: CA Hand Clutch Adjustment?
    Posted: 01 Oct 2023 at 9:45am
My CA hand clutch does appear to be partly functional, however there is very little "spring" action.  The spring only operates to return the handle about an inch from the rearward position.  From there, you have to manually return the handle to the forward position.  What's the likelihood this can be resolved with an adjustment versus a rebuild?  The clutch was worked on last by a local car repair shop, that occasionally worked on tractors.  I'm unsure whether it worked correctly after that as it wasn't used very long after that.
Edited by dfwallis - 01 Oct 2023 at 10:25am
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2023 at 7:26pm
Does anybody know the part number for the hand clutch shim pack?  I find 223166 online, but doesn't mention CA in any listing, only D10/D12 and later.
HudCo View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2023 at 8:47pm
if any thing you probley need to take shims out
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2023 at 12:32pm
CA axle clutches DO NOT have any shims, unless someone added some after machining off too much when doing a rebuild.
  The Shim pack for a D10/12  IPTO clutch would not even be close to what could be used in a CA axle clutch as it is of a completely different design.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2023 at 6:44pm
Ah, I guess I got confused by watching a vid that I thought was a CA vid but wasn't...:(
