custom pistons |
JamesP
Topic: custom pistonsPosted: 18 May 2023 at 4:08am |
Any suggestions on where to get pistons made? Model UC, thanks
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5274 |
Posted: 18 May 2023 at 7:37am |
Not sure they can make all pistons, but EGGE makes some custom pistons for really old engines.
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3812 |
Posted: 18 May 2023 at 8:17am |
I spoke with Dan Karpel @ Crank Machine service a few years ago about pistons for a UC after he did a crank for me and he had a source. He suggested making a fiberglass resin cast of the head chamber to give most accurate shape for best dome configuration. Life has gotten in the way and i have yet to do it. Id be interested in doubling your order depending on what you go with, if you decide to roll with it. I guess we have talked this over James, but dont remember if i ever got you the contact info
Edited by CAL(KS) - 18 May 2023 at 8:28am |
Dad- WD, D17D, D19D, RT100A, 7020, 7080,7580, 2-8550's, 2-S77, HD15 |
JamesP
Posted: 20 May 2023 at 3:37pm |
Hey Cal, I am sending one of my pistons to extreme tractor parts-Ray.
I ended up having my sleeves bored .030 over. I am having .500 added to compression ht. This will be 7-1 CR and the piston will be .060 below the spark plug hole so it wont require any features on top. Calculates show hp around 65. Plenty for me, I am not competing just want enough that it never powers out on the fun pulls and I can still hand crank it-- LOL. I am only guessing but with your stroke, it would push the piston up enough to gain a lot more compression plus CI. You could buy new sleeves and rings and run stock pistons.??
NEVER green
Posted: 21 May 2023 at 9:37am |
Check Ross, and Diamond.
2-8050 1-7080 6080 D-19 modelE & A 7040 R50
CAL(KS)
Posted: 22 May 2023 at 7:35am |
cms
Joined: 29 Nov 2010 Location: collinsville il Points: 71 |
Posted: 25 May 2023 at 9:52am |
Can help with custom pistons.
Dan Karpel |
