How Much Fuel is Needed?
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Topic: How Much Fuel is Needed?
    Posted: 09 Feb 2023 at 12:41pm
For a 301, 3100 rpm, 2.3 smooth bore charger, 7000lb and 18.4x38 tires, will a 450 Roosa Master put out all the fuel that you will need?  We can run a Bosch Model 100 rotary if necessary.  Thanks!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2023 at 6:16am
Let's say both pumps delivered the same CC's of fuel at 3100 RPM BUT, the M-100 did it in less degrees of crankshaft rotation. That's the pump I'd want to use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2023 at 7:13am
Thanks, Dr.  I appreciate  your reply.
