Forum Home Forum Home > Allis Chalmers > Farm Equipment -Knowledge Base
Industrial tractors question
Walker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Topic: Industrial tractors question
    Posted: 31 Jan 2023 at 6:08pm
Just curious about mounting a 3 point hitch plow on an industrial tractor? I don't know if they have draft control or not? Other than front axle being a bit  low is there any other reason you couldn't do some farming with one that has 3 point and PTO?
Edited by Walker - 31 Jan 2023 at 6:09pm
DaveKamp View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2023 at 9:00pm
Hi Walker!
So, you've already pointed out one  of the first characters of an industrial, vs ag tractor-  the front end height... industrials are usually lower, and frequently have non-adjustable axles or wheels, in lieu of heavier units for physical strength.  Frequently they'll be fitted with wheels that accept other 'types' of tires (compaction, aircraft, or 'more road-ish' type tires for use on pavement... typically they'll be a little wider in the back, and a whole lot wider in the front, as they don't have to fit through narrow rows, but do need more contact surface.  A lower center of gravity is preferred (there's no row-crop clearance needed) and more overhead clearance is desired (one need not loose their head over going through doorways).
Sometimes there's different gear ratios.  Sometimes they're fitted with fewer total speeds, but alternative features like shuttle-shift.  Some Allis industrials have (instead of high-low on the power director) a forward-reverse, and someone correct me if I'm wrong, because I've seen it on other brands, i THINK Allis did too), the gearbox has no reverse, instead, it might have 5 speeds, so with the shuttle, it's 5 fwd, and 5 rev?  Great for running a front loader...
Which brings up point:  Where is the "Industrial Tractor" used?
Many different ways... in many different environments 'not agricultural'.  Factories often use them for moving large components or supplies to assembly lines, typically on flat trailers or other situations where forklifts cannot do so as effectively or safely.
They're often fitted with front end loaders and backholes.  They're sometimes fitted with snow plows or throwers (usually these have cabs with heat and lights).  Sometimes they're fitted with bristle brushes and water tanks (for clearing pavement),  Some have sickle bars or other special mowers.
There's some very special 'industrial' tractors reserved specifically for aircraft tug use.  I don't know what Allis did, but I know others (Minneapolis-Moline) took a very svelte tractor, got it low, with massive tires, ballasted the heck out of it, and put in rediculously low gears, for pulling bombers and heavy transport aircraft.
Industrials were often reversed and used as forklifts... shuttle shift is a great thing here.
And my favorites were fitted with PTO generators and large magnet arrays on front, in middle, and back, and run down aircraft runways to pick up stray pieces of ferrous metal, to get the pavement clear of tire-eating debris.
The only IMMEDIATE issue to mounting a 3-point hitch plow on an industrial might be height... you might find that once in a furrow, with one tire on the hard, and the other in the row, is that the whole assembly sits so low, that the plow's lift height just isn't enough to clear the point as you reach the end of a row.
Generally, industrials were pretty limited in their hitchery... a drawbar at rear, and frequently one would see one up front (oftentimes added by the user) to back or jockey trailers into tight spaces.
No reason it CAN'T be done, but the agricultural features would likely be missed.  As a handy 'utility', it'd be convenient, simply because you're down low, and can be on and off easily.
Dean (West MI) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2023 at 9:44pm
If the industrial tractor is based off the D15, it probably doesn't have the belly pump used for the 3 point on the ag tractors. You would have to tap into the front pump hydraulic system. Also, if the D15 based industrial tractor has a shuttle shift, it would have a faster spinning PTO.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2023 at 12:50am
I have a IH 460 Utility and 16.9 X 24 tires on rear , 5 speed with fwd/rev shuttle shift . 17 GPM hyd pump for loader 3.5 GPM steering pump piggybacked onto other pump , front axle is IH 560 outer hubs on solid tube axle
 IH Fast hitch rear and valve body with 3 sections but can be ganged to for more . Fast hitch has draft control an IH kind of adjustment for traction booster for attachments to fast hitch
Seems each mfg had some form of utility or industrial to fit market need .
Post Options Post Options   Thanks (1) Thanks(1)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2023 at 6:22am
Many Industrial tractors had factory installed 3pt hitches as landscapers used them as well as other light construction outfits. In general the only ones not having a 3pt would have had a backhoe when new.  Often these also had whatever draft control was on a comparable farm tractor.
 I used to have an Allis Chalmers I40 that had a factory mounted loader, PTO and factory 3pt with the same traction booster controls and linkage as a D10/12 would have had. It also had a mechanical reverser in place of the Hi/Low range a farm tractor would have had. The reverse gears were still in the main transmission, just that shift rail was pinned to prevent its use.
 Previously I had an Industrial D10 that had Backhoe mounts and someone had just mounted 2 Jeep frame weights in place of the backhoe. I removed the weights and backhoe mounts, then installed all of the parts necessary for a snap coupler hitch as all the needed holes were there. As it had originally had a Backhoe, it didn't have a PTO, I plumbed the hitch lift into the loader hydraulics and only had Lift/Lower control of the hitch.
  I also know of many Ford Industrial tractors that were factory equipped with PTOs and 3pt hitches with the draft control of the time. I've also seen many  Massey Ferguson, Case and John Deere Industrial tractors that had the same factory PTOs and 3pt hitches as comparable farm tractors and beyond the paint the only other difference was the HD front axle.
