ARGO 6x6 ...yeesh..
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: ARGO 6x6 ...yeesh..
    Posted: 28 Jan 2023 at 9:40am
so neighbor drives his 2nd hand, 59 hour, 'hard starting' ARGO over for me to look at.....
hmm, 23HP B&S Vanguard engine. if you bypass the starter solenoid (screwdriver), nice...
so probably needs a new solenoid...
OK, WHERE's the 'engineer' who decided that using a gear clamp to secure the solenoid onto the starter was a 'good' idea ??  I want him here, NOW, to replace the solenoid !!!
There is NO way a normal human can do it.heck I can't even 'feel-find' the clamp screw.
 OK, no big deal,if you're stuck in the bush, there's always the recoil start.... NOT. Same 'engineer' expect you to remove the 'firewall' ,fish your hand through a maze of SHARP mechanically things then pull the cord ??? I'd like a demonstration please !
At the end of the 3 hours , I had 2 suggestions(3 really,shhhh ) 1..keep long screwdriver IN the ARGO, so jump start when needed...... 2) spend 2 dayze this summer and rotate the recoil from 9oclock to 2oclock.
They may be 'cute' and 'useful' but NOT easy to work on.
Kansas99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kansas99 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2023 at 11:09am
Should have got a terra tiger  Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2023 at 9:02am
heck, I'm just HAPPY that I will NOT be working on it !!!
