226
Ol case mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ol case mike Quote  Post ReplyReply Direct Link To This Post Topic: 226
    Posted: 24 Dec 2022 at 4:20pm
Dr Allis
Can you give me any info on a Allis motor 226
17-60197-Z was told it’s a gleaner Z code I installed it into 36 WC with electric start will be used for fun pulling nothing much serious yet just getting started has 150psi cold cranking hoping for 8-1 wondering what year and what it come from any info is good info thanks Mime
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2022 at 4:32pm
Cannot tell you the year. It is a "Z" compression code, which means 8.0 to 1 compression, which should test at 160 to 170 PSI all four plugs removed, throttle wide open, warmed up and a battery charger on the battery. As long as the compression is even all the way across, it's fine. "M" code is 7.25 to 1 compression for a D-17 tractor. With the combine's Marvel Schebler carburetor, I'd expect 67 flywheel HP at 1650 RPM's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ol case mike Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2022 at 5:16pm
The motor was out of a D17 but was told it was a combine engine it was grey I enlarged a WD crank pulley made an oil line drilled out Water pump holes made a fuel pump plate removed power steering pump runs good . I used a WC governor spring will be changing carb to D19 or case DC for starters
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2022 at 5:51pm
Tractor engines were never grey or had a fuel pump on them from the factory, so yes, it was a transplant at sometime in the past. And for accuracy, it is called the G-226 engine used in the D-17 and Gleaner E-series combine. The W-226 engine is from the WD45 and while they are very similar, they are NOT the same engine. Crankshafts and blocks are completely different.
Edited by DrAllis - 24 Dec 2022 at 9:49pm
