Allis g engine |
Kiwi
Joined: 23 Jan 2018 Location: New zealand Points: 393 |
Topic: Allis g enginePosted: 25 Jun 2022 at 11:16pm |
Hi all I am trying to get a engine for my G running it was meant to be a runner I have a good spark and when I tip some gas down the spark plug hole and hand crank it all i get is flames out the exhaust were do I go from this point and what do I try next .
Tractors Allis EB,two C,diesel G
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5311 |
Posted: 26 Jun 2022 at 5:35am |
It sounds, to me, like your timing is way off, maybe even 180 degrees?
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7720 |
Posted: 26 Jun 2022 at 9:04am |
I agree, sounds like timing is off.
WF owner
Posted: 26 Jun 2022 at 10:01am |
Also, be very careful hand cranking if you aren't sure the timing is right. When it sparks at the wrong time, it could easily kick on the crank and the crank could hit you. There have been MANY broken arms from cranking an engine that is slightly out of time.
Kiwi
Posted: 26 Jun 2022 at 10:19pm |
Hi all I think I have the timing about right no flame out the exhaust it now puffs smoke and sounds like it wants to go. a bit more tinkering and I should have it running
Kiwi
Posted: 28 Jun 2022 at 12:05am |
Hi all I am as happy as a dog with two tails I have been able to get this little G engine to run and it runs smoothly.
WF owner
Posted: 28 Jun 2022 at 5:15am |
Was the problem the timing was off?
Kiwi
Posted: 28 Jun 2022 at 3:07pm |
Yes it was out by 180 degrees and a new set of spark plugs
