Forum Home Forum Home > Allis Chalmers > Farm Equipment -Knowledge Base
PS leak on a 100 Series Under The Hood ??
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: PS leak on a 100 Series Under The Hood ??
    Posted: 27 May 2022 at 6:57pm
Seems like there's been info on this ailment and only 3 seals required for the  "fix" ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2022 at 5:55am
There's "under the hood" and there's "up thru the steering column". Under the hood is usually a hose or an Oring on one of the 4 hose connections. Up the steering column is generally a new seal kit installed in the orbitrol. So, which is it ??
Edited by DrAllis - 28 May 2022 at 5:57am
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2022 at 7:50pm
Apparently, from the steering console. Dad said it was leaking hydraulic oil from under the gas tank. Thanks for the reply
