FS 1951 CA
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Topic: FS 1951 CA
    Posted: 19 Dec 2021 at 7:15am
I have this 1951 model CA pin hitch tractor available that sells with 2 row cultivators. This is a pin hitch tractor and was originally a magneto tractor that now has a distributer conversion. It has a 6 volt system. The engine runs great and has most likely had engine work done before I got it. It has matching Safemark tires all around, 5.00X15 fronts, 12.4X24 rear. Located in Maryland, very near Gettysburg Pa.
It has many NEW parts;
Engine clutch
wiring harness, switches & amp gauge
Radiator, thermostat & Temperature gauge
Electronic Ignition conversion & coil
Voltage regulator
seat pan
Here's the engine oil pressure at idle when warm.
 It has had the axle clutch rebuilt and it doesn't slip.
 The rebuilt generator is a 2 brush style from a D10 that has a higher output than the 3 brush that would had been on a CA
I'll sell it complete with the cultivators for $2000. It is ready to go to work and needs nothing. I got this tractor to use with a mid mount WOODS mower while I was rebuilding the engine in another CA and no longer need this one. The battery is only a few years old.  I have replaced the bushings in the rear lift shaft and added grease fittings. It does not have lights although It is wired for the headlights.
Edited by PaulB - 19 Dec 2021 at 8:00am
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2021 at 3:58pm
SOLD   Thanks to all that were interested and messaged me, Especially to Chris who now has a "new to him" toy for Christmas Big smile
