Bluetooth problem
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Topic: Bluetooth problem
    Posted: 04 Dec 2021 at 10:49am
The Bluetooth for the phone on my 2013 F150 only works when it wants to. I have tried removing the fuse, disconnecting the battery, and resetting it with the buttons but no luck. When it does work it connects with my phone as it should. Any suggestions other than replacing the radio?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2021 at 11:32am
Does your phone 'see' the truck as a bluetooth 'device' ?
Depending on the phone/OS, you may have to TELL the phone to KEEP 'seeing' the truck.
Maybe try someone else's phone ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2021 at 6:22pm
Fix-Or Repair-Daily LOL Wasn't life so much easier before most everyone became so dependent on these type of things? In the 70s & 80s I travelled all over the east and never knew what GPS was, nor did I have a cell phone. All I had was a phone number and a town. I always found where I needed to go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2021 at 7:11pm
My phone "sees" the truck just fine. The Bluetooth just works intermittently. If it is working, it works until I turn the truck off, then it may not work again for numerous starts. I can do without it, I just don't like having something that doesn't work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2021 at 7:59pm
Hubert, it might not help, but you  might REBOOT and start over and reload the phone.. See if any steps are missing .... since it works part time, this probably will not help... might be INSIDE the radio as you said.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2021 at 8:06pm
Does the radio always act as the Master, the phone has gotta be a slave.  Also you may try just turning the truck to ON and let them connect and then start it.  If you go to start too fast they may not have a chance to connect and then can't once the truck is running.  Just a couple of random thoughts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2021 at 8:12pm
Another random thought, check your battery terminal connections...Wink
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2021 at 10:05pm
Have you noticed if it works when the phone is plugged into recharge?
At work, we have ‘Big Road’. And it will alert us if our phones are not plugged into recharge, even if our phone battery is 100%
Edited by Lars(wi) - 04 Dec 2021 at 10:05pm
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2021 at 6:36pm
Hubert, I have a 13 F150 also and my phone has always worked fine. I would first try telling the truck to forget the phone and do the same on the phone, then start over with adding a new device on the radio menu. If that doesn't work try rebooting the Sync computer, should be in the owner's manual I can't remember how to get to that right now. There has been one software update for the Sync system also since they were new, I don't know if it's still available if you don't have it.
Dirt Farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dirt Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2021 at 12:34am
I just cant resist...but did the blue run out of the oval in the grill, is that the blue tooth fluid someone on here was asking about a while ago? Refill and problem solved
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2021 at 10:04am
 LOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2021 at 5:50pm
Thumbs UpClap
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2021 at 8:48pm
My 94 seems indifferent to my cell phone but seems to get excited when I put in a new cassette tape. Just fickle I guess.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
