7030 hydraulic spool
Smallfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smallfarm Quote  Post ReplyReply Direct Link To This Post Topic: 7030 hydraulic spool
    Posted: 24 Jun 2021 at 5:44pm
WTB 3rd spool and linkage for a 7030. Also looking for the high-low-park lever. Call or email reuben1390@gmail.com or 715-864-1897
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2021 at 8:49pm
To help with your desire to add a third remote valve to a 7030, there are a couple of things to consider. #1. All 7030/7050's originally had remote couplers clear up high under the SMV sign. Are your current couplers like that?? or have they been updated to the lower (under the left lift arm) outlets ??  #2. Do you currently have cables controlling your valves?? or solid linkage ??  Any way you do it, you will still need four tie bolts that are long enough to go thru all the valves. That issue doesn't change.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smallfarm Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2021 at 9:12am
Our valves are still up high with cables.
