Hadely PA Pull 5-22-21 |
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8689 |
Topic: Hadely PA Pull 5-22-21Posted: 23 May 2021 at 10:04pm |
Folks,
RPM check station: Regards, Chris
Edited by Sugarmaker - 23 May 2021 at 10:08pm |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4242 |
Posted: 24 May 2021 at 2:38pm |
so how did everything go
Sugarmaker
Posted: 24 May 2021 at 6:47pm |
Hud, Folks,
It went well. 3500 lb. Division 1: I pulled the Allis WZ, got first place 306 ft, Only one other in class, Allis WC pulled 250 ft. 3500 lb. Division 2: I pulled the WZ , got first place at 316 feet. two others in class, Farmall C and Oliver 66, at 312, and 256 feet. 4000 lb. Division 1. Jim pulled the WZ with added weight to first place at 212 feet. 5 others in class including me with the WD 45 and I came in dead last. Tried the right side of the track and it was soft. Bad move on my part. 4000 lb Division 2: I pulled the WD45 233 feet beating Jim on the WZ at 221 ft followed by three other pullers at 212, 205 and 198, on Ford 961, Farmall H and a Farmall C. 5000 lb Division 1: Jim pulled the D17 293 ft for 3 place, he missed second place by 2 ft, the 961 Ford got good traction and won the class at 345 ft. (I think I need to get the front end a little lighter) 5000 lb Division 2: Jim finished in 6th, missing 5th by 8 feet, first went 343 ft on a Oliver 88 to 343 ft. Regards, Chris
Sugarmaker
Posted: 24 May 2021 at 8:05pm |
Folks,
We really did pull!:) Regards, Chris
