O/T FORD TRACTOR PART
Matt Tallant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt Tallant Quote  Post ReplyReply Direct Link To This Post Topic: O/T FORD TRACTOR PART
    Posted: 13 May 2021 at 10:57am
I am looking for a air cleaner gasket for a 1100 compact Ford Tractor P/N
SBA314530390 Thanks for any help
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2021 at 1:02pm
Matt, i may be way off base on this... but many air cleaner "gaskets" are actually a square rubber ring that seals the cover... You can buy square rubber material by the foot from McMaster, cut to length and RTV it inside the cover , or put adhesive on the ends and make it into an O-ring.... ??? ... if that is what your needing.
This page was generated in 0.103 seconds.
