7000 Series weights
allischalmers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmers Quote  Post ReplyReply Direct Link To This Post Topic: 7000 Series weights
    Posted: 12 May 2021 at 7:30pm
I am looking for 7000 series suit case weight stops/hold downs. Bought a 7030 and have no weight stops.
Thanks Max
WD45,C,3 B's
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2021 at 9:04pm
Were still available at AGCO a couple years ago if unable to find used
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2021 at 9:54pm
Agco is where i ordered mine 67.00 a piece?
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2021 at 9:55pm
if you order them check the part numbers as i believe there is a right and a left one  i ordered 2 of the same it works but my weights are off center
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2021 at 10:25pm
Same keeper part left or right. Weight count is 15 or 21 for thin weights.  10 or 14 weights for the thick 2 1/4" weights.  Wrong total weight count can make them sit to one side.
Darb210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darb210 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2021 at 7:18am
i have a set near Pandora Ohio 45877, $150 buys the pair.  4192303362  AJ
