WANTED: WD45 Spindle Supports/Spindles-wide front
ssccrab View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssccrab Quote  Post ReplyReply Direct Link To This Post Topic: WANTED: WD45 Spindle Supports/Spindles-wide front
    Posted: 06 May 2021 at 7:09am
I'm in search of spindle supports and spindles for my a wide front WD45. The spindles on it currently are completely seized and seems like no amount of PB, heat, or beating on it will push them out. Any help is appreciated!
Edited by ssccrab - 06 May 2021 at 7:21am
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2021 at 7:55am
If I remember correctly there is a keyway in the Steering Arm.
You have to turn the Steering Assembly upside down and pound the Steering Arm off the Spindle.
G
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2021 at 12:27pm
SS
Did you understand my post about the keyway, and that is not the problem?
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2021 at 10:21pm
Been a long time since I worked on mine but I believe the 2 tapered bolts hold the arms with no key. Should be able to remove taper bolts and then arms.
ac-mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac-mike Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2021 at 8:31am
Bring them to me and I will disassemble them. Will not hurt them anymore than they already are.
D-12III, 200D, 170G, HD-3, D19D 3pt, D17D High Crop, WD45G p/s, D15IID, D15IIG, D15G IND, 655, (3)WD45D p/s, 700, 816
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2021 at 3:31pm
I have the wide front axle for sale. 300$. In iowa can ship
phil
