2 8070 tractors on auction
harm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote harm Quote  Post ReplyReply Direct Link To This Post Topic: 2 8070 tractors on auction
    Posted: 28 Apr 2021 at 8:19pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2021 at 7:22pm
Thats a great sale - thanks for the info
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2021 at 10:51pm
was it just me or were they the only two allis listed
harm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote harm Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2021 at 9:17am
bump
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2021 at 9:04pm
1982 8070, 18.4-38s, duals, Lower rear window shattered, Passenger door been off & sitting in shop since AC quit years ago, Blew the hydraulic hose under cab that goes to Power Shift Trans rear filter, Pulled it 3/4 mile home - not running, Sat outside 4 years with top rear window opened, drivers door tied shut, & no passenger door. Cab interior rotted away. Clutch pedal moved easily, Front tires weathered but up. Inside rear weights(1/side), inside tires fair, & duals weathered hard. Both holding air. 2 hyd outlets & top link. Brought $5010 at auction today.
Edited by AC7060IL - 13 May 2021 at 9:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2021 at 9:11pm
1982 8070, 18.4-42 duals, 3500 orange engine block (gleaner engine?)& crank not moving from turning fan belts, injection fuel pump weights remove & left open, all its windows & doors intact & closed, no top link, quit running 4 years ago & been sitting outside since, clutch peddle not budging, no rear weights, no front weights, & busted up side panel & grill frame. Tires weathered all around. Cab interior average. Brought $4630 at auction today.
This page was generated in 0.093 seconds.
