82S mower for sale
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Topic: 82S mower for sale
    Posted: 12 Apr 2021 at 7:37am
I removed it from a WD. It has been sitting a long time. All the brackets are present. I have an adapter for the side mounting to fit a D series. I am not sure if the rear WD mounts would work on a D series. $500. You would need a cylinder and hose.
jlogli View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2021 at 8:37am
Do you happen to have a bracket for a series 4 D17?
1945 WC on full steel, WD wide front, WD45 power steering, 1966 D-17IVfactory 3 point.1967 D-17IV SC. 1973 rotobaler white top. orange top roto, model 90 combine,82S, four bottom plow.302 baler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2021 at 10:33am
I have one on my WD, they are really good mowers. Makes it very nice as you look ahead not backwards. Having the D series mount also is a great asset. They are easy to remove and put on the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2021 at 7:19am
I don't have the bracket for the series 4.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2021 at 7:22am
I have one on my WD45 and it works very well. I might put this on my D17. I like to show mounted implements on tractors.
This page was generated in 0.142 seconds.
