CA overheating |
Zinan
Topic: CA overheatingPosted: 16 Oct 2020 at 1:49pm |
My dads CA over heated last time i ran it above about the 6th throttle notch, and not under much load, just mowing my yard, I stopped to check the mower deck (It kept making a banging noise but I got it fixed) and i heard the coolant boiling, im thinking i need to atleast flush the coolant and maybe inspect the radiator, any other reasons for it to over heat?
sparky
Joined: 13 May 2011 Location: So. Indiana Points: 1866 |
Posted: 16 Oct 2020 at 2:05pm |
Thermostat?
Zinan
Posted: 16 Oct 2020 at 2:10pm |
dont know why i didnt really think of that, i also need to get the temp gauge fixed (It reads zero no matter the temp) |
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 93294 |
Posted: 16 Oct 2020 at 2:14pm |
It may or may not really be "overheating".. You will hear "snap / crackle/ pop as the hot water runs thru the system.... having some type of temp gauge would not hurt to know the actual temp.... Flushing is always a good idea.... Some of these tractors have thermostats and some have lost them over the years... Is possible that it failed partly open.
Zinan
Posted: 16 Oct 2020 at 2:19pm |
it was defiantly over heating, i could hear the coolant almost boiling over lol
steve(ill)
Posted: 16 Oct 2020 at 2:25pm |
Check radiator cap also... If you have a few pounds pressure cap ... then the boiling temp is 230- 240 F.... If the cap maintains no pressure, you can hear the water bubble and boiling is 212 F. ...... Im not for or against a pressurized cap, just saying that it changes the boiling point... and must maintain some type of seal.
Zinan
Posted: 16 Oct 2020 at 2:28pm |
will do
CTuckerNWIL
Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Posted: 16 Oct 2020 at 2:34pm |
Anytime you shut a warmed up engine off, you could hear water boiling, because it isn't being circulated anymore.
Do get a temp gauge, and it can't hurt to flush the rad. |
Zinan
Posted: 16 Oct 2020 at 2:37pm |
makes sense
Zinan
Posted: 16 Oct 2020 at 2:39pm |
lets see if anyone reading this thread gets to this comment, (I didnt want to make a new thread although i feel like i will anyways) the final drive clutch seems to have a extremely snappy engagement, ive seen people using the hand clutch, and theirs seems to be able to slip, any ideas?
Bill Long
Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
Posted: 16 Oct 2020 at 3:27pm |
First, I do not know the year of you CA only that it could be up to 70 years old. The years they we made was from 1950 to 1957. If you have a hand clutch this is still releasing and engaging you are extremely lucky. Even new they "snapped" It is necessary since the axle clutch has to hold a higher torque load.
Let us know how it goes. The CA was one of the best tractors I sold. One of the very best plowing tractors A-C made. As to your overheating, the CA was a rather "cool" running tractor. The heat gauge hardly ever got to the green section. Be sure to give it a careful and complete flush. Over the years there could have been a lot of build up in the block. Good Luck! Bill Long
Zinan
Posted: 16 Oct 2020 at 3:53pm |
I think ours is either a 1952 or 53, id check the serial number on the transmission, but its been painted so many times the numbers are filled in
Jim.ME
Posted: 16 Oct 2020 at 4:05pm |
Some other things to consider as well.
Did you check the radiator before you started mowing to know it was full? Coolant should have been within an inch to an inch and a half below the cap seal flange.
Is the outside of the core clean? When cool has the radiator been washed/flushed from fan side to the front with a water hose to wash the fins out? Is the fan belt tight? I have a CA and being snappy is the nature of the axle clutch. you can ease it in if you work at it. It is common to have to scrape the paint off to see the serial number, then repaint after. Edited by Jim.ME - 16 Oct 2020 at 4:08pm |
Zinan
Posted: 16 Oct 2020 at 4:15pm |
radiator was full, fan belt seems ok, although we have never washed out the radiator fins, i might do that later, maybe tomorrow since i wont be busy
Brian Jasper co. Ia
Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
Posted: 16 Oct 2020 at 4:25pm |
I have a CA and it's hand clutch is snappy in the lower gears with nothing heavy hitched to the tractor. It's pretty much the nature of the beast. Get a working temp gauge and be sure it's getting too hot before you get too worried about it as long as it's not boiling over.
Jim.ME
Posted: 16 Oct 2020 at 4:30pm |
I've started double checking even new temp gauges with a non contact thermometer (temp gun), many are off calibration, at least the last few I've gotten. Gives me an idea of how much they are high or low.
Zinan
Posted: 16 Oct 2020 at 6:55pm |
that is a smart idea
Zinan
Posted: 16 Oct 2020 at 6:56pm |
I dont even think you could get ours moving without killing it using the hand clutch with it in anything other than first gear
