500 loader tip cylinder
Don Jr NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don Jr NY Quote  Post ReplyReply Direct Link To This Post Topic: 500 loader tip cylinder
    Posted: 08 Oct 2020 at 4:03am
Hello all. Would anyone have an old 500 series loader lying around they are parting out? I am looking for a tip cylinder for one. The cylinder from a 400 loader is a different length so it has to be from a 500 to match my other one. Any and all leads appreciated.  Don Jr.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don Jr NY Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2020 at 3:35am
Anyone out there have anything? Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2020 at 7:43pm
Don, don't give up. They can be had time to time. If you can wait might get one. I was about a year before I found one here. If you need one soon, might as well have someone make them or covert to standard from a hyd supplier. HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2020 at 6:58am
Gonna hate it if have to find a New One.  About the only way to get one now is to have a GOOD Hydraulic shop build one.  They generally have all the tooling to do this or access to suppliers for a basic cylinder that can be reduced in length to produce a replacement.
Uncertain how long the supplier I am using will remain in business as the owner has no one beating his door down to take over and he is closing in on retire.  He services close to seven states.
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2020 at 9:26am
I can get aftermarket to fit  not cheap , thanks
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2020 at 10:57am
Check Surplus Center in NE they have 100 and 100 of cylinders match up the length of throw. The ends can be changed with some cutting and welding.
