WTB: AC 6-7 ft disc
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: WTB: AC 6-7 ft disc
    Posted: 19 Sep 2020 at 11:10pm
Want to buy a good shape 6-7 foot SC or 3 point AC disc. I prefer a heavier model that will cut well. Thanks Tracy
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 12:11pm
Tracy, here is a picture of my SC #109 disc.  I enjoy it but it's not really heavy enough to cut much in dry, hard cornstalk ground.  It does okay in the spring in soft dirt or in soybean stubble that's been softened up by a little rain.  If you're looking for something that will cut, I think you need to look at a 200 series or possibly newer.  A 2100 series is the last of the mounted disc harrows made by AC.  Good luck in your search.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 1:33pm
Brian, I have a 109 disc myself. It cuts as you say. It is too wide to go between some rows in garden at times when I want to disc up and replant new veggies. It cuts good enough for that , just to wide. My wheel discs are a pain to manuver inside the gulag! Thanks tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 6:30pm
I measured my tread width on SC D12, 6 foot will work on it for sure. Thanks tracy
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2020 at 2:59pm
Tracy did you ever get that slip clutch you was hunting? I have a roto baler with a slip clutch. PM if your still looking
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2020 at 3:06pm
PM sent. Tracy
