426 copper headgasket thickness
goomer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote goomer Quote  Post ReplyReply Direct Link To This Post Topic: 426 copper headgasket thickness
    Posted: 26 Aug 2020 at 9:41am
What thickness copper do you use to make a head gasket for a 426? thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2020 at 10:35am
Depends what you're trying to do. What are you using for fire rings?? or no fire rings?? I guess generally I'd think the same thickness as the OEM head gasket, but it depends on other things.
Post Options Post Options   Thanks (0) Thanks(0)   Quote goomer Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2020 at 10:55am
fire rings with groove cut into sleeve. Guessing stock thickness. will the copper crush at all?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2020 at 3:00pm
You'd better ask who grooved your sleeves and what size fire ring. It doesn't crush very much. A .030" wire will crush into it, but I never figured the whole gasket crushed maybe .001".
bsallis180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2020 at 4:36am
.025 deep grove .065 gasket and .015 cruch
.105 thick ring
