Wd45 governor???
Acllss puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acllss puller Quote  Post ReplyReply Direct Link To This Post Topic: Wd45 governor???
    Posted: 30 Apr 2020 at 10:01pm
To DrAllis and who ever . We rebuilt our Wd45 engine - high compression and super light pistons and shaved 4ozs off governor weights , seems way to responsive wants to run away with very little throttle movement. Thoughts opinions ideas ? Thanks
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2020 at 5:41am
Why did you shave the weight?
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2020 at 9:17am
You haven't synch'd the gov linkage to the carb. Engine off. Throttle wide open. Diusconnect link rod from governor arm. The link rod should just slide back into the hole and I'll bet the gov arm is farther back that the link rod. Bend link rod down or bend gover arm forward. 1/8" wrong makes a HUGE difference in governor action.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acllss puller Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2020 at 7:51pm
Thanks !!!
