7010 pto reassembly |
190 driver
Topic: 7010 pto reassemblyPosted: 13 Feb 2020 at 5:48pm |
I'm putting new seals in the two speed pto on my 7010. When putting the bearing on the front of the 1000 rpm solid shaft, is it best to heat the bearing to install or tap the shaft into it? I can't see where pounding the shaft into the bearing would be good for either the bearing or the race.
MACK
Posted: 13 Feb 2020 at 7:44pm |
I have always driven the shaft into bearing. Don't fit all that tight. MACK
190 driver
Posted: 18 Feb 2020 at 5:21pm |
Thanks for the advice. It went on better than anticipated. How tight
does the big nut on the solid shaft go? Just snug or snug and a little
more? Snug and back off? The I&T isn't real good on things like
this.
DrAllis
Posted: 18 Feb 2020 at 5:33pm |
Just tight enough that there isn't any looseness in the stack of parts. You get it too tight and it will fry that flat needle bearing. On the same note, any looseness and your seals will leak.
190 driver
Posted: 18 Feb 2020 at 6:09pm |
Thanks for all your help. That's kind of what I figured.
MACK
Posted: 18 Feb 2020 at 9:06pm |
I like to tighten the but tight to make sure all the slack is out, then loosen to where it turns free. MACK
MACK
Posted: 18 Feb 2020 at 9:07pm |
NUT not but. MACK
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29821 |
Posted: 20 Feb 2020 at 7:04am |
There's a joke in there that I'm leaving alone
Wink I am a Russian Bot |
