D-17 IV Splitting tips |
barnabas_12
Joined: 23 Jan 2010 Location: New Prague, MN Points: 52 |
Topic: D-17 IV Splitting tipsPosted: 20 Apr 2019 at 6:21pm |
Went to split my D17 today, and I've having trouble with the steering shaft knuckle. The manual doesn't say anything about dealing with the steering shaft, but the gear on the end is not going through the adapter housing. Am I missing something? Otherwise, what's the best way to get that knuckle apart?
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 56061 |
Posted: 20 Apr 2019 at 6:24pm |
IIRR, the best way is to hammer the spring pin out, so only the shaft goes through the hole...
DrAllis
Posted: 20 Apr 2019 at 6:52pm |
Drive the lower pin out of the knuckle before you split it. Turn the steering wheel hard to make the rust let the shaft free up/spin loose from the knuckle. WD40(or the like) sprayed into the pin hole helps free things up.
