WD45 hand clutch question |
Alan L (MO)
Topic: WD45 hand clutch questionPosted: 11 Apr 2019 at 2:56pm |
the hand clutch on my 45 doesn't have any "resistance" when pushed or pulled. When engaged and driving, if i stop abruptly the hand clutch moves forward and disengages the drive. it used to stay back and took some effort to move forward to disengage. any advice would be appreciated.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 9234 |
Posted: 11 Apr 2019 at 4:00pm |
Take cover off and look.Sounds like big snap ring came off back off clutch
MACK
Posted: 11 Apr 2019 at 9:38pm |
Need to remove cover and remove some shims from all three places. Could also rotate over center plate to a different place. While in there, check for pins that may have fallen out. MACK
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2595 |
Posted: 12 Apr 2019 at 6:24am |
If the big snap ring comes off, it is always engaged. Does the tractor still stop (or slow to a creep) if you push the clutch lever forward? AaronSEIA
Alan L (MO)
Posted: 12 Apr 2019 at 9:48am |
yes, the clutch functions, just has no tension. you can move it forward and backwards with virtually no resistance. |
AaronSEIA
Posted: 12 Apr 2019 at 10:18am |
I'm with Mack. Almost has to be shims. Does it hold good when engaged? I'd take the battery box and cover off and give it a look. Service manual says how to adjust the shims. AaronSEIA
HD6GTOM
Posted: 12 Apr 2019 at 10:24am |
If you remove shims be sure and save them.
Alex09(WI)
Joined: 15 Mar 2012 Location: CECIL WI Points: 1792 |
Posted: 12 Apr 2019 at 6:44pm |
Yes definetly shims need to be removed. I bet if you put it in 2nd and stomp on both brakes when moving, you will come to a complete stop because the hand clutch is slipping. I would reccomend moving the over-center plate also. A properly adjusted hand clutch should take more than 40lbs of pull on the handle to engage it over center. Also the snap ring has no effect on if the clutch disengages or engages. My wd45 had no snap ring when I got it and still doesn't and the hand clutch has been working fine since then (4 years)
www.awtractor.com
A&W TRACTOR 920-598-1287 KEEPING ALLIS-CHALMERS IN THE FIELDS THROUGH THE 21ST CENTURY |
MACK
Posted: 12 Apr 2019 at 9:10pm |
Axex09 is correct, the snapring only keeps the two parts as one. MACK
