Allis C compression value
John426 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John426 Quote  Post ReplyReply Direct Link To This Post Topic: Allis C compression value
    Posted: 09 Apr 2019 at 11:39am
Hi
What is the compression ratio or the PSI compression for an Allis Chalmers C distillate
On the web i see differents ratio from 70 PSI to 115 PSI . What is the correct one for distillate engine?
Mine is the tractor number 50953 , i think that production date is last quarter of year 1947
Edited by John426 - 09 Apr 2019 at 11:41am
Leon n/c AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon n/c AR. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2019 at 11:44am
Several year ago when I checked our old B best I remember it was somewhere between 60-70 psi.
Post Options Post Options   Thanks (0) Thanks(0)   Quote John426 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2019 at 11:48am
I checked mine , i have 65 PSI on each cylinder, but my question is does it O.K or to low?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2019 at 12:22pm
If the compression is 65 psi on ALL four cylinders, AND it runs OK, why are you concerned??  The only way to correct it is to overhaul it. It sounds like it does indeed have the distillate pistons in it. You did check the compression with the throttle set WIDE OPEN didn't you ???
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2019 at 12:53pm
Are you all talking about the dished kerosene pistons? My "B" had those, and it had 90 psi in all 4 before I overhauled it with gas flat top pistons.
Post Options Post Options   Thanks (0) Thanks(0)   Quote John426 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2019 at 1:39pm
I have flat piston
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2019 at 1:51pm
4.75 c/r is 99 lbs
5.75 c/r is 115 per the book.
AaronSEIA
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2019 at 8:50pm
Should be mentioned in the shop manual:
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
Gerald J.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2019 at 8:57pm
Originally posted by John426 John426 wrote:
I have flat piston
Flat top pistons can also be low compression pistons when they do not come even with the deck when at TDC.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2019 at 9:00pm
Aaron............. not sure how they got those numbers...... atmospheric pressure is about 14.7 psi ................ if you had a 5:1 compression motor, you should get 5 x 14.7 or  about 70 psi ................ if you had 6:1 compression, you would get about 85 psi..... I don't see how any of the small allis motors would put out  100 psi since then all had less than 7 :1 compression ...... ??????
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2019 at 6:49am
I don't know either.  Just quoting the AC service manual.  The BE engine was 4.67 c/r at 84 lbs and the 4.92 c/r at 94 lbs.  I'm assuming "compression pressure" is on a compression test gauge.  I don't think I have an I&T manual to see if they say the same thing.
AaronSEIA
This page was generated in 0.083 seconds.
