Non-detergent engine oil
Slowmotion View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slowmotion Quote  Post ReplyReply Direct Link To This Post Topic: Non-detergent engine oil
    Posted: 05 Apr 2019 at 8:32pm
I know the pros and cons of detergent vs non-detergent motor oil have been discussed, but I think I'll go with non-detergent in the WD I recently bought, and I'm wondering what's available. All I've found, with one exception which is very expensive, is not for automotive type engines.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2019 at 9:15pm
What could possibly be the advantage of using non detergent oil? Every motor I have seen pulled down that used non detergent oil had crud built up in it,usually packed tight under the valve cover.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2019 at 9:26pm
I would start using the detergent oil like every other motor in the world does today. Monitor the oil and see if crud starts to break off and dirty the oil... If the motor is that dirty / sludge inside.... you have problems anyway .......... might as well get it cleaning out..... your motor will thank you 2 years from now.
Maybe pull the valve cover and LOOK ?
Dmpaul89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2019 at 9:34pm
any farm and home type store like rural king will have it. if thats what you want. Last time I looked rural king oil was under $10 a gallon for sae 30.     the autoparts stores like autozone, oriely, etc will be double the cost.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2019 at 4:15am
I can see the "what's the best non-detergent motor oil available" question coming next.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2019 at 4:35am
I'll throw in to roil the waters, Royal purple oil!  No wait, Amsoil!Wink
savedallis1953 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote savedallis1953 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2019 at 5:33am
Go with single viscosity detergent.
1953 WD, 1953 WD, WD engine with WD-45 crankshaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2019 at 6:04am
Motor oil with zinc additives. Off the top of my head I can't think of a non-detergent oil with zinc.
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2019 at 7:59am
Sp how come you wanta do something like that to the ole girl? Confused
Phil48ACWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2019 at 11:21am
Non Detergent engine oil died long before Elvis for real good reason. DON'T USE IT!!!!!!!!!!
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2019 at 12:29pm
The main purpose now for having non detergent oil is to lubricate anything that is exposed to moisture such as water pump bearings and seals, electric motor bearings, pressure washer pump oil, etc. Detergent oil and moisture will form a sludge that takes out seals and bearings.
BEK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BEK Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2019 at 1:09pm
Tractor Supply Co. has Travelers Non-Detergent 30wt in five quart jugs. It was on sale for $9.99.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2019 at 1:27pm
Ok, I will be the dissenter here.
I have a WD45 that I inherited from my Dad. As far as I know, it has never been overhauled. Since I only run it in warm weather, I use 30W non-detergent oil. It's what Dad always used; 10W in the winter and 30W in the summer. It has run well for many years. I see no reason to switch.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2019 at 1:38pm
I'm a black sheep here too, as I use non-detergent oil in my tractors. I've bought it lately from Tractor Supply in the 5 qt jugs like BEK said for $9.99, but I have historically used NAPA brand non-detergent at $1.99/qt.
When I overhauled the engine in my B, it was very clean inside, and all I'd ever used was non-detergent, and that's all the PO used. I have reason to believe it was never overhauled before, as the crank/rod bearings all had AC part numbers, and it had the original kerosene pistons still in it.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2019 at 5:32pm
Back when car engines changed from non-detergent to detergent oil, engine life increased a great deal. Besides the detergent to keep the oil from solidifying there is another additive that prevents water in a bearing between the copper or silver lining and the steel crankshaft from making a battery that is ordinarily shorted and so eats the bearing lining. I have read many articles long ago about the effects of detergent oil, in Lubrication Magazine probably about 1950.
In my opinion running any engine on non detergent oil is abusing the engine.
Gerald J.
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2019 at 6:06pm
Converted our tractors decades ago to detergent oil. After the conversion, we ran it for maybe 10 to 20 hours and dumped the oil and filter and then just stayed with the 100 hr filter/ oil change. Never had any issues with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slowmotion Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2019 at 8:59pm
I've read many times in many places that changing to detergent oil in an engine that has been run for many years on non-detergent oil can dislodge enough of the accumulated gunk to clog things up and do serious damage. I've also read of people who have made the switch with no problems whatsoever. Since I don't know the history of the tractor and don't want to pull any more apart now than I have to, I think the prudent thing to do is to run it on non-detergent for the time being. If I were to overhaul an engine, I would definitely start out with detergent and keep it that way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2019 at 9:00pm
But, there may be something to be said for the old "bypass" filtering system on a WD and using non-detergent oil in an old engine.  Detergent oils carry the dirt to the full flow filter which traps the dirt and lets the oil move on to lubricating things. The bypass system only filters a small percentage of the oil per minute instead of 100% per minute like full-flow systems do. So, do you want to pump dirty oil every minute to engine parts with detergent oil?? or let some of the dirt settle and separate from the oil ??  I would only use good detergent oil if I knew the engine was clean inside.
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2019 at 11:17pm
I have never seen an engine manufacturer recommend non detergent oil for an engine ( at least since the introduction of detergent oil). I have this argument all the time on small engine pages. People say to use non detergent when there is no oil filter etc. But no one ever has any supporting documentation. Read owners and shop manuals for all small engines from all manufacturers and they all say to use detergent oil. The big engines are the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2019 at 6:50am
Most compressor manufacturers now specify HD synthetic oil.
If the engine is filthy there might be some dirt around the seals which may prevent some oil from leaking past the seals. Detergent oils may clean that dirt away, possibly causing more seal leakage. I would consider using non-detergent oil as a crutch in this case, not a permanent solution. The fix is to replace the seals if they leak after switching to detergent oil. If you bought a used tractor from someone, the odds are he was already using detergent oil. If the seal are leaking now, switching to non-detergent will not fix that problem. Why switch back now?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slowmotion Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2019 at 12:00pm
On the side of switching to detergent oil, at the time detergent oil became available millions of motorists switched, and I don't recall hearing any horror stories about engines failing, and I don't recall reading about or hearing of any warnings about what the switch could do to your engine. But maybe I just don't remember.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2019 at 12:05pm
Only purpose for non Detergent these days is gear box oils, no need of the detergent value but will not hurt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2019 at 4:14pm
Oils are like women; 10 different guys will like 10 different ones and they will all have their own reasons.
Some guys think they need to use full synthetic only. They feel like the best oil is the only option. Other guys will use the cheapest things they can get their hands on and have decent luck with it.
As I have posted before, I retired from NYSDOT after 31+ years. I never saw an engine failure in any engine that was attributed to engine oil and they use recycled oil.
I do what I think is right and I can give you reasons. Someone else might do exactly the opposite and they can give you reasons. Make your own choices and live with the consequences.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2019 at 4:41pm
If you're going to change the oil every 100 hours, per the original schedule, you don't need an expensive oil. Much less a synthetic oil. In any case, I'd still use a detergent oil. As for recycled oil, if I used that in either of my cars and they found out, it would void the warranty. Both manufacturers specify synthetic only. Mineral oil is acceptable if it's an "emergency," but they state to drain and refill with synthetic as soon as possible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2019 at 7:47pm
This was the main reason I stick with non-detergent in my old bypass oil filter engines. Plus, my 1951 Chevy with NO oil filtration system...
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2019 at 8:52pm
Creston,back then they sold add on bypass filters for the old stovebolts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2019 at 9:10pm
I know, I just don’t have one. If I could find one I might consider it, but it’s gone 68 years and has very little crank wear.
garden_guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2019 at 10:01pm
The only place I use non-detergent oil these days is in my WD's hydraulics. I've got some cheapo 20 weight non-detergent stuff that works great for plowing and remote cylinder use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slowmotion Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2019 at 9:04pm
How much oil does the WD take when the oil and filter are changed?
This page was generated in 0.159 seconds.
